How to Bolt hood latch on
Old Jan 26, 2020 | 11:51 AM
abody's Avatar
Trying to find out what the type of nut the bolt gets secured to, when I bolt the hood latch on the hood. It’s for my 70 supreme.
Old Jan 26, 2020 | 12:43 PM
70Post's Avatar
On the factory hood LATCH (the "hook" looking piece that you pull up on with your fingers AFTER you pop the hood LOCK)....the LATCH already has nuts built into it. It's held onto the underside of the hood with two 5/16" hex flange bolts.
Old Jan 26, 2020 | 01:26 PM
abody's Avatar
Thank you
Old Jan 26, 2020 | 01:30 PM
abody's Avatar
My bolts go into the latch, but my hood doesn’t have anything for the bolt to tighten too. Does a clip style spring nut go onto the hood?
Old Jan 26, 2020 | 04:32 PM
442crzy's Avatar
Put hood latch inside hood and line up the two holes in hood with the two holes in latch, then install 2 bolts. The latch is secured to the hood now.
Old Jan 26, 2020 | 05:16 PM
abody's Avatar
w2green
Body work
Jun 22, 2022 04:11 AM
72cutlassolds
Sep 1, 2014 08:29 AM
mruders
Jul 17, 2014 09:57 PM
D.Mac
Dec 23, 2011 10:12 PM
georgiaboy697
Jul 2, 2010 09:23 PM
