Tach reading
Old Jun 4, 2019 | 09:36 AM
Ricko442's Avatar
Tach reading
Anyone know how to get the factory tach to read rite ?
the distributor has the pertonix electronic set up in it instead of points .
i heard you have to put some sort of resistor in the line going to the coil.
Old Jun 4, 2019 | 10:00 AM
RandyS's Avatar
Pertronix simply replaces your points, but does not change how your tach works. (which is based on the pulses sent to the coil) Some tachs can be switched between 6 or 8 cylinders. This can cause incorrect readings.
Old Jun 4, 2019 | 11:15 AM
Texas69's Avatar
Tach
There is a small adjusting screw accessible from the rear of the tach casing behind a foil sticker.
Old Jun 4, 2019 | 11:19 AM
It should work the same as with points, needs to be hooked to the coil- terminal.
Old Jun 4, 2019 | 11:44 AM
nicks1966's Avatar
Big Daddy Spo
Jul 6, 2021 02:20 PM
Peter Lufrano
Jun 16, 2017 06:01 PM
jimjific
Jun 3, 2017 06:36 PM
jon566
Mar 21, 2017 08:22 AM
Don Cannoli
Jul 13, 2016 02:57 PM
