Tach reading
Tach reading
Anyone know how to get the factory tach to read rite ?
the distributor has the pertonix electronic set up in it instead of points .
i heard you have to put some sort of resistor in the line going to the coil.
Pertronix simply replaces your points, but does not change how your tach works. (which is based on the pulses sent to the coil) Some tachs can be switched between 6 or 8 cylinders. This can cause incorrect readings.
