When did olds put the highbeam switch
Old February 12th, 2018, 07:19 PM
ph_ckstick1
midnightleadfoot's Avatar
on the column?
my 75 salon it is on the column but the rug has the cut out and rubber like ring for the floor switch.
midnightleadfoot is offline
Old February 12th, 2018, 07:52 PM
cherokeepeople's Avatar
you sure it has the correct steering column.my sister had a 77 cutlass and it was on the floor.i didnt think they went to turn signal mounted dimmer til at least 78.
cherokeepeople is offline
Old February 12th, 2018, 07:56 PM
same but different
don71's Avatar
That is a good question.
Are you sure your steering column is original to your car?
Gm often offered an option on one make and would soon make it available to other lines of its products.
Specific to your Olds related question, I can't answer it. Someone with a stack of Oldsmobile factory manuals can tell you for sure.
don71 is offline
Old February 12th, 2018, 08:03 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I think it went to he column on the Delta 88 and the 98 in 1977. I am not 100% sure.
redoldsman is offline
Old February 12th, 2018, 08:57 PM
stevengerard's Avatar
I had a '76 regency and I am pretty darn sure it was still on the floor. It was a few year later that I got my foot stuck in the steering wheel trying to turn on the brights.
stevengerard is online now
Old February 12th, 2018, 09:02 PM
ph_ckstick1
No idea if the column is original, it matches the rest of the interior blue, but that don't mean much..
but it is correct for a floor shifted car(or it would seem) as there is no stock/mount for a column shifter..
Old February 12th, 2018, 10:34 PM
My '77 Supreme Brougham had it on the floor, I had a '77 Grand Prix LJ, and it was on the steering column.
1969w3155 is offline
Old February 13th, 2018, 03:19 AM
rob1960's Avatar
The dimmer switch on the column was part of the Salon option since it came out, Pontiac Grand-Ams had it also. My girlfriends 43k original '76 Salon has the column dimmer like it should & it has a rubber plug in the carpet where the floor dimmer would have been.
rob1960 is offline
Old February 13th, 2018, 03:46 AM
ph_ckstick1
OK just seemed odd, I went to flash the high beams and could not hit a switch, the next morning went looking for it , figured the maybe the switch was removed or carpet moved/etc. and no switch.. looked at column and could not make out the faded font on the small plastic piece near stock, and slowly and carefully pulled back on the stock and ding ding ding highbeams.
My 1975 I had in the early 90's it was on the floor, but it was a base car I'd guess, 260v8 and bench seat, and well that was it.
Old February 13th, 2018, 07:26 AM
jaunty75's Avatar
Not that it matters any more since the question has been answered, but the dimmer switch on my '78 Toro is on the floor.
jaunty75 is offline
tcolt
January 19th, 2018 09:35 PM
safray
June 9th, 2016 08:22 AM
69442murph
June 14th, 2011 11:34 AM
NewOldsGuy
January 3rd, 2011 07:44 PM
ztim
April 20th, 2008 11:12 AM
Quick Reply: When did olds put the highbeam switch
