When did olds put the highbeam switch
Old Feb 12, 2018 | 07:19 PM
midnightleadfoot's Avatar
ph_ckstick1
on the column?
my 75 salon it is on the column but the rug has the cut out and rubber like ring for the floor switch.
Old Feb 12, 2018 | 07:52 PM
cherokeepeople's Avatar
you sure it has the correct steering column.my sister had a 77 cutlass and it was on the floor.i didnt think they went to turn signal mounted dimmer til at least 78.
Old Feb 12, 2018 | 07:56 PM
don71's Avatar
same but different
That is a good question.
Are you sure your steering column is original to your car?
Gm often offered an option on one make and would soon make it available to other lines of its products.
Specific to your Olds related question, I can't answer it. Someone with a stack of Oldsmobile factory manuals can tell you for sure.
Old Feb 12, 2018 | 08:03 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I think it went to he column on the Delta 88 and the 98 in 1977. I am not 100% sure.
Old Feb 12, 2018 | 08:57 PM
stevengerard's Avatar
I had a '76 regency and I am pretty darn sure it was still on the floor. It was a few year later that I got my foot stuck in the steering wheel trying to turn on the brights.
Old Feb 12, 2018 | 09:02 PM
ph_ckstick1
No idea if the column is original, it matches the rest of the interior blue, but that don't mean much..
but it is correct for a floor shifted car(or it would seem) as there is no stock/mount for a column shifter..
Old Feb 12, 2018 | 10:34 PM
My '77 Supreme Brougham had it on the floor, I had a '77 Grand Prix LJ, and it was on the steering column.
Old Feb 13, 2018 | 03:19 AM
rob1960's Avatar
The dimmer switch on the column was part of the Salon option since it came out, Pontiac Grand-Ams had it also. My girlfriends 43k original '76 Salon has the column dimmer like it should & it has a rubber plug in the carpet where the floor dimmer would have been.
Old Feb 13, 2018 | 03:46 AM
ph_ckstick1
OK just seemed odd, I went to flash the high beams and could not hit a switch, the next morning went looking for it , figured the maybe the switch was removed or carpet moved/etc. and no switch.. looked at column and could not make out the faded font on the small plastic piece near stock, and slowly and carefully pulled back on the stock and ding ding ding highbeams.
My 1975 I had in the early 90's it was on the floor, but it was a base car I'd guess, 260v8 and bench seat, and well that was it.
Old Feb 13, 2018 | 07:26 AM
jaunty75's Avatar
Not that it matters any more since the question has been answered, but the dimmer switch on my '78 Toro is on the floor.
tcolt
Jan 19, 2018 09:35 PM
safray
Jun 9, 2016 08:22 AM
69442murph
Jun 14, 2011 11:34 AM
NewOldsGuy
Jan 3, 2011 07:44 PM
ztim
Apr 20, 2008 11:12 AM
