Trunk lock rusted shut?
Old Jan 10, 2018 | 08:42 AM
orangepower1987's Avatar
As the title says, I think my trunk lock is rusted shut. I've left the trunk open to avoid disaster and been lubricating the lock with PB Blast. I have the correct key, but cannot get it to turn. Any suggestions to either fix or replace the lock? I'm hoping to keep the same trunk and just replace the lock. Any help is appreciated.
Old Jan 10, 2018 | 09:01 AM
Rustbucket2's Avatar
I would remove the lock, put into a small pan with evapo-rust, that should free it up.
Old Jan 10, 2018 | 09:23 AM
Any idea how to remove this lock?
Old Jan 10, 2018 | 10:53 AM
coppercutlass's Avatar
Chevy budget Olds powered
soak it up with deep creep a good heat gun will help too. I wouldn't put fire to it but a heat gun will help.
Old Jan 10, 2018 | 11:06 AM
if it's on a 71 cutlass , there are 3 bolts holding it to truck lid, if it's the lock cyl, there is one screw, and you pull down on metal clip, it should pull out .
Old Jan 10, 2018 | 03:19 PM
CRUZN 66's Avatar
Olds Fever
First, you need to determine if the problem is with the lock or the key lock cylinder... Separate the lock cylinder from the lock mechanism by removing the clip/retainer for the lock cylinder and pulling the cylinder out from the trunk lid... Using a thin blade screw driver try to function the lock mechanism through the lock cylinder hole... If the lock still will not turn the mechanism is the problem... Also test the lock cylinder by inserting the key and making sure it will turn freely... If you can't turn the key inside the cylinder the tumblers are most likely worn causing the problem, or even the key could be worn to a point where it is not fully engaging the tumblers...
Old Jan 10, 2018 | 05:59 PM
It is a 71 Cutlass S. I was born in 1987. Lol. Thank you everyone! Can’t wait to try these out!
Old Feb 6, 2018 | 03:35 PM
Well I ran into a problem and looking for help. Anyone have any experience with trunk locks? The key hole came apart in the evaporust and I’m not sure how to get it back together.
Old Feb 6, 2018 | 04:20 PM
The bezel is crimped onto the cylinder housing. A locksmith should be able to crimp it back on for you, assuming there is sufficient metal left on the housing. It came apart for a reason, and it may be loss of metal due to corrosion.
Old Feb 6, 2018 | 04:55 PM
CRUZN 66's Avatar
Olds Fever
What does the back side of the bezel look like??? As stated above, the bezel just crimps over the cylinder... It is possible the lip on the cylinder is worn and won't allow the bezel to stay in place...
Old Feb 6, 2018 | 05:15 PM
Like you said, it definitely holds in some positions, but as soon as I rotate the cover (pardon my terminology) it comes back off. So the “cover” as I call it should be crimped over he lock cylinder itself correct?
Old Feb 6, 2018 | 05:57 PM
Charlie Jones's Avatar
Phantom Phixer
I , myself , would just buy a new trunk lock . Comes with keys ;
https://www.ebay.com/sch/i.html?_odk...+lock&_sacat=0
Old Feb 6, 2018 | 08:43 PM
ordered. Thank you for your help
Old Feb 6, 2018 | 08:55 PM
Any idea if these keys will work on the glove box? I know the trunk and glove box are the same key.
Old Feb 6, 2018 | 09:16 PM
Phantom Phixer
Not unless you can find a SET of trunk and glove box locks and change both .
Old Feb 11, 2018 | 09:05 AM
All right everyone! Thanks for your help. The trunk can open and shut freely! Woo! On to the glove box lock.
goldie442
Aug 21, 2015 11:01 AM
Wyze
Dec 20, 2009 05:57 PM
American Lead
Apr 20, 2009 12:47 PM
d.smith1
Jan 30, 2008 12:08 PM
