67 Cutlass auto floor shifter placement/location
Old November 17th, 2017, 10:56 AM
Govt slave
squirell's Avatar
Hi Guys,
I am finally doing my bucket/console conversion on my 67 Cutlass.
I got the buckets in, now it's time for the shifter.
Anyone have measurements as to exactly where the shifter mounts to the floor ?
Also measurements on where the hole goes for the floor shifter cable ?
Also found this "key card" under the carpet..found it interesting
Thanks in advance
squirell is offline
Old November 17th, 2017, 03:37 PM
Govt slave
squirell's Avatar
wiring
Also,
What do I do about the wiring on the shifter itself ?
2 purple.. 1 light green.. 1 dark green
squirell is offline
Old November 17th, 2017, 06:30 PM
steverw's Avatar
I dont have the measurements you need, even though mine is a floor auto, its all covered now and no time to measure. Someone here will have those measurements you need. I have used Lectric Limited wiring harnesses, they have the console extension harnesses for the neutral safety switch and console lighting. Very nice quality. I think M&H also has these harnesses and probably American Auto Wire. I love that color interior on one.
Good luck
Steve
steverw is offline
Old November 19th, 2017, 09:58 AM
brianbeez67's Avatar
I have my interior apart, let me know if you only need the measurement for the shift cable. If need more then lets figure out some interior land marks to take measurements from and off we'll go
brianbeez67 is offline
Old November 20th, 2017, 02:24 PM
Govt slave
squirell's Avatar
Brian,
Thank you,
I think I got it in the right spot.
I had to fab a new bracket for the attaching point on the transmission and trans pan, but car won't go to 2nd or 1st.
I ordered the correct (hopefully) brackets yesterday.
http://www.jegs.com/i/B%26M/130/3549...gn=retargeting
Lets see what happens with the new brackets.
Then I have to figure out the neutral safety switch and reverse lights...ugg
squirell is offline
Old November 20th, 2017, 02:44 PM
Govt slave
squirell's Avatar
Good luck
Steve
Thank you Steve
squirell is offline
Keener
December 24th, 2016 03:52 PM
Bglad
April 16th, 2015 11:56 AM
Bronco Fan
March 22nd, 2013 06:58 AM
arodenhiser
November 15th, 2010 02:06 PM
1960es
September 4th, 2009 03:02 AM
Quick Reply: 67 Cutlass auto floor shifter placement/location
