67 Cutlass auto floor shifter placement/location
Old Nov 17, 2017 | 10:56 AM
squirell's Avatar
Govt slave
Hi Guys,
I am finally doing my bucket/console conversion on my 67 Cutlass.
I got the buckets in, now it's time for the shifter.
Anyone have measurements as to exactly where the shifter mounts to the floor ?
Also measurements on where the hole goes for the floor shifter cable ?
Also found this "key card" under the carpet..found it interesting
Thanks in advance
Old Nov 17, 2017 | 03:37 PM
squirell's Avatar
Govt slave
wiring
Also,
What do I do about the wiring on the shifter itself ?
2 purple.. 1 light green.. 1 dark green
Old Nov 17, 2017 | 06:30 PM
steverw's Avatar
I dont have the measurements you need, even though mine is a floor auto, its all covered now and no time to measure. Someone here will have those measurements you need. I have used Lectric Limited wiring harnesses, they have the console extension harnesses for the neutral safety switch and console lighting. Very nice quality. I think M&H also has these harnesses and probably American Auto Wire. I love that color interior on one.
Good luck
Steve
Old Nov 19, 2017 | 09:58 AM
brianbeez67's Avatar
I have my interior apart, let me know if you only need the measurement for the shift cable. If need more then lets figure out some interior land marks to take measurements from and off we'll go
Old Nov 20, 2017 | 02:24 PM
squirell's Avatar
Govt slave
Brian,
Thank you,
I think I got it in the right spot.
I had to fab a new bracket for the attaching point on the transmission and trans pan, but car won't go to 2nd or 1st.
I ordered the correct (hopefully) brackets yesterday.
http://www.jegs.com/i/B%26M/130/3549...gn=retargeting
Lets see what happens with the new brackets.
Then I have to figure out the neutral safety switch and reverse lights...ugg
Old Nov 20, 2017 | 02:44 PM
squirell's Avatar
Govt slave
Good luck
Steve
Thank you Steve
Keener
Dec 24, 2016 03:52 PM
Bglad
Apr 16, 2015 11:56 AM
Bronco Fan
Mar 22, 2013 06:58 AM
arodenhiser
Nov 15, 2010 02:06 PM
1960es
Sep 4, 2009 03:02 AM
