1 piece oil pan gasket 455
Old May 7, 2016 | 01:02 PM
69CulassConvertible's Avatar
Hello-
Thanks for taking time to read this. Does anyone know of a manufacturer of a one piece oil pan gasket for a 455cid ( 1973)?
thanks!
Old May 7, 2016 | 01:16 PM
Originally Posted by 69CulassConvertible
Hello-
thanks!
I'm not aware of one. Note that all 1964-1990 Olds V8 oil pan gaskets interchange.
Old May 7, 2016 | 03:30 PM
Thanks Joe I appreciate your reply, all V8 engines Oldsmobile 1964-1990 no matter the displacement share the same oil pan gasket? You would think someone would've come up with a form fit one piece gasket then, for so many vehicles able to use it.
Dave
Old May 8, 2016 | 06:59 AM
Dave
All 1964-1990 Olds V8 blocks share the same architecture. The only substantive external difference between the small block and big block Olds motors is the deck height. Oil pan flange is the same, as is the gasket. The SBOs used a different pan, as did Toro motors, but the differences are in the overall shape. There are no differences in the gasket flange and SBO/BBO/Toro pans all can be swapped.
Old May 8, 2016 | 08:47 AM
Thanks Joe-
Have you any experience with The Right Stuff or Yamabond, as replacement for the multi-piece oil pan gasket?
Old May 8, 2016 | 10:42 AM
Thanks Joe-
I've always just used FelPro.
Old May 8, 2016 | 12:39 PM
The thing about the oil pan gasket that makes a one-piece gasket unlikely is that the flat portions along the pain "rails" require different characteristics than the portions that run transversely across the front and back of the engine and curve around the bearings.
Old May 8, 2016 | 02:02 PM
That problem has been solved, Eric. FelPro and others sell a one-piece gasket for Type C engines. The reason no one makes them for Olds is that there isn't sufficient demand to justify the development and tooling cost.
Old May 8, 2016 | 02:07 PM
Wow. I guess it's been a long time since I messed around with "those" engines.
That's kind of cool - eliminates the common leak points at the joints.
Old May 8, 2016 | 03:36 PM
I think you still have to use RTV in the 4 corners.
Old May 8, 2016 | 07:27 PM
83hurstguy's Avatar
I've used those expensive 1 piece gaskets on type-C engines... and they leaked in both cases. We actually took one of them back off, used right stuff on both sides of it, re-installed, and it started seeping a year later again. I'm not sure if it was the gasket or the pan, but I wasn't overly impressed.
On the Olds engines, I've had decent luck with the steel core gasket that was referred to as the "diesel" pan gasket.... Fel Pro OS30471C. I use the Right Stuff on a lot of places (e.g. intake manifold end rails), though I can't say it's given me better results in preventing leaks on the oil pan. If nothing else, cleaning it up later sucks... it's tough.
hessdawg
Nov 6, 2024 03:03 AM
atkinsom
Jan 17, 2013 07:55 PM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
dallasite21
Jun 20, 2010 05:37 AM
1973olds98
Sep 26, 2009 01:59 PM
