Wiring question.
Wiring question.
Ok guys i know this is probably simpler but im double checking here.
IM wiring my car up with a race car panel. So you start the car with a push button. But i still want a way to have an anti theft.
I want to wire My ignition though the key so thats the only way to arm it.
In that harness that runs to the steering column is there a hot 12 key source i can tap into ????
I know i can check with a test light but !!! at the moment i cant power up the car. is there a specific color wire on the key switch i can use?
Anyhelp is appreciated. Trying to wire it up as much as possible before i power anything up but i know it can be done later.
On the ignition switch at the base of the steering column, there is a big red wire that is a constant +12V from the battery.
The heavy pink wire is +12V when the ignition switch is turned on.
oldzy
September 10th, 2009 05:23 AM
