68 442 a/c wiring question
I need to know which wires go where on the relay for factory a/c on a 68 442. The relay is mounted on the passenger side front fender on the inside of engine compartment. It has three terminals. I know on terminal goes to the compressor and two got to the harness, but which wires connect to the relay and which terminals? You can see the relay mounted on the insdie of the right front fender
oldzy
Sep 10, 2009 05:23 AM
