Wipers won't park
Old Nov 11, 2017 | 09:31 AM
Roger60's Avatar
Wipers won't park
67 Cutlass. What would cause my wipers not to park when turned off at the switch? Motor? Switch? Thanks.
Old Nov 11, 2017 | 10:14 AM
Is this a new issue or has it always operated like that?
Old Nov 11, 2017 | 11:42 AM
Roger60's Avatar
Just assembled restoration. First time I've tried them.
Old Nov 11, 2017 | 11:48 AM
Park relay, relay contacts, or wire to the relay.
Old Nov 11, 2017 | 03:39 PM
Roger60's Avatar
Is the relay contained in the wiper motor?
Old Nov 12, 2017 | 06:58 AM
Yes, and it is actually a solenoid that both operates electrical contacts and moves the tab that engages the park actuator. It is the white unit at the bottom of this photo:
Here is the relay by itself (yes, this one has the terminals in a different location than the one in the photo above):
Old Nov 12, 2017 | 07:08 AM
Roger60's Avatar
Thanks, Joe. I have another motor assembly I'll try it.
Old Nov 12, 2017 | 09:52 AM
RandyS's Avatar
What years of this style of wiper motor are interchangeable?
Old Nov 13, 2017 | 09:51 AM
TripDeuces's Avatar
Out of curiosity does the wiper run off the windshield on the drivers side and unto the chrome strip?
Old Nov 14, 2017 | 04:31 AM
Roger60's Avatar
No, runs normal, just doesn't stop at bottom when shut off.
Old Nov 15, 2017 | 09:28 AM
Roger60's Avatar
Very simple fix. Unit was not grounded. Failed to put a washer over the mount with the brass ground. D'oh!
HLS
Feb 12, 2015 04:14 PM
jlelec
Jul 5, 2014 10:28 PM
HLS
Mar 5, 2014 07:13 AM
jdharris76
Sep 10, 2012 11:50 AM
d.smith1
Jan 30, 2008 12:08 PM
