Window motor electrical connector
Old Sep 22, 2024 | 06:07 PM
79cut's Avatar
Hello all
replacing a window motor
the electrical connection plug is different than old one
anyone come across this ?
Old Sep 22, 2024 | 06:19 PM
Originally Posted by 79cut
Hello all
Yes, The ones I've gotten came with a short adapter harness.
Old Sep 22, 2024 | 06:24 PM
79cut's Avatar
oh. I would have to cut my harness and make different connections.
I have to confirm if I got right motor first
Old Sep 23, 2024 | 10:52 AM
cfair's Avatar
As I recall there are right and left motors, but front & rear on a given side can be interchanged.
In the older days GM used a “T” shaped connector which was changed along the way, I’m guessing when they “went metric” or thereabouts.
If you’re mixing & matching, you’ll should be able to find or make an adaptor. If you make something, solder the connections and use shrink wrap since these are high amperage connections which heat up on top of living inside the weather-exposed door & quarter cavities.
Good time to shop vac those door and quarter bottoms for loose screws, dirt and spare change…
Hope that helps
Chris
Old Sep 23, 2024 | 02:47 PM
https://www.lectriclimited.com/produ...er-harness-27/
Old Sep 23, 2024 | 02:57 PM
79cut's Avatar
thank you
Old Sep 25, 2024 | 05:21 PM
79cut's Avatar
What I have
Plug is different
New plugs
Old Sep 25, 2024 | 05:36 PM
You do realize that isn't even close to the same motor, right?
Old Sep 25, 2024 | 05:38 PM
79cut's Avatar
Ya figuring that out
Old Sep 27, 2024 | 07:31 AM
79cut's Avatar
I ended up buying the Cardone motor 82-016
motor looked the same but gears inside didn’t match up the round gear housing on mine was much deeper than these.
I ended up swapping my housing onto the new motor
going to see how this is all going to work this weekend
what a pain and this motor is 4 x the price
rand5204
Sep 17, 2021 06:10 AM
Arrowstorm
Vista Cruiser & Wagons
15
Jan 21, 2016 05:36 AM
1BOSS83
Oct 24, 2013 09:51 AM
1BOSS83
Hurst/Olds
Apr 11, 2013 06:42 AM
redrumloa
Jul 28, 2008 06:16 PM
