water pump I.D.
Old July 14th, 2021, 02:52 PM
scrappie's Avatar
water pump I.D.
Can anybody tell me the application for this water pump please?
scrappie is online now
Old July 14th, 2021, 03:00 PM
66SportCoupe's Avatar
1970-1990 Olds V8
66SportCoupe is offline
Old July 14th, 2021, 03:38 PM
scrappie's Avatar
Thx, would that be with ac or not?
I have a friend looking for a water pump for a 1970 cutlass with 350 no ac, no HD cooling. Wondering if this is what he needs?
Old July 14th, 2021, 03:39 PM
Mr Shifty Sidney's Avatar
Don't believe that pump is factory correct for anything pre 1972. I think they started using the "4" pump on the early 70s? Try to google the number cast into housing for a more positive answer.
Mr Shifty Sidney is offline
Old July 14th, 2021, 03:46 PM
Google is what said 70-90 most likely 72 or later.
Old July 14th, 2021, 03:50 PM
412265 is just the casting number. That same casting was used to build different P/N pumps for different applications, all were 6.1" pumps. It could have come with one bypass outlet or two. The two outlet pump P/N was 556283, with applications as follows:
1975-1982 260 with A/C
1980-1988 307 with A/C
1978-1985 350 diesel
1973-1980 350 with A/C
1977-1979 403 with A/C
1973-1976 455 with A/C
joe_padavano is offline
Old July 14th, 2021, 04:53 PM
1970-1990 Olds V8
The water pump outlet nipple is 2" diameter on 1970-older water pumps and 1.75" on 1971 and newer water pumps, so the same pump can't have an application for 1970 and also for 1971-newer.
Fun71 is online now
1970VistaCruiser
April 11th, 2021 09:18 PM
Mike Sundy
August 11th, 2016 07:34 AM
J-(Chicago)
March 30th, 2013 02:54 PM
Nor Cal Andy
March 20th, 2011 04:03 PM
scott_442
October 12th, 2009 11:07 AM
Quick Reply: water pump I.D.
