vent lines
Old Aug 25, 2011 | 02:10 PM
1967cutty's Avatar
vent lines
hi i have a 1967 cutlass supreme. The gas tank has 2 vent lines that come off the left rear of the tank. Gas comes out these lines, i tried to hook hoses to them and run it around the tank to a piece that has both lines connect to it but its open at the top and gas just comes out of it, does anyone have any suggestions on where i should start.thanks aron
Old Aug 25, 2011 | 03:43 PM
There is a replacement tant vent kit through OPG, yearone, etc...
This is the one from yearone:
http://www.yearone.com/serverfiles/f...vent&SM=1&SC=3
You will just have to pick up some fuel line.
Old Aug 25, 2011 | 06:21 PM
1967cutty's Avatar
are you talking about the white piece,i have that piece ,how are you supposed to run the lines for it.thanks
Old Aug 26, 2011 | 06:39 AM
There are 2 lines that run from your fuel tank to the white piece. The white piece is held in place by a bendable bracket above the license plate, behind the bumper. What probably happened is the lines are dry rotted and need replaced. Just take a piece of each line to the local parts store and have them match it up.
Old Aug 27, 2011 | 01:22 PM
1967cutty's Avatar
hi i did what you said drove about 5 to 10 miles to a friends house everything was fine no leaks. When i drove back home i checked it and it was leaking , what should o do now?
Old Aug 28, 2011 | 06:52 PM
1967cutty's Avatar
Does anyone have any advice i need all i can get? thanks
Old Aug 28, 2011 | 08:08 PM
hookem horns's Avatar
You need that plastic surge piece mentioned above and mounted up above the tank, least I did on my 69. Sometimes a little "burp" in the vent spits out gas unless ithe surge valve is in place to let it go back down the other line. I got creative and ran an extra line out of it to filler neck so I can cap the vent when garaged and reduce fumes. Keeps wife happier and I put a reminder on the dash to remove before driving.
Old Aug 30, 2011 | 07:38 AM
1967cutty's Avatar
I already have the surge piece that the vent lines hook up to. Im lost right now
Old Aug 30, 2011 | 08:24 AM
Is your gas cap vented or non-vented, you need to use the non vented cap with this setup! Mine does not have the plastic piece on the end. I used a looped piece of metal tubing clamped into the end of the hoses, with a non vented cap, however my tank will build some residual pressure. Not enough to harm anything!
Old Aug 30, 2011 | 06:13 PM
glord's Avatar
I have a '66 442 with the Fuscik 1966/1967 replacement tank. It has the two vent lines coming out of the driver-side rear of the tank. One is crimped, and one connects it to the Vent Hoop in the trunk that was used in '66. This with an unvented cap. With this setup, theoretically, I should not build up tank pressure but unfortunately on hot days I do build up pressure, enough so that the car starts to stall. As soona s I relieve the pressure by removing the cap, it runs fine.
I am going to try a vented cap to see of that helps but I'm at a loss as to why the venting system is not working. I'm beginning to suspect that the replacement tank is not plumbed properly such that the pickups are below the fuel line as opposed to above. Unfortunately there is no way to tell short of cutting into the tank.
I'm curious as to whether or not others have had this experience with the reproduction tank offered by Fuscik.
Thank you
Old Aug 30, 2011 | 10:03 PM
2blu442's Avatar
I've found that plastic piece on 1969's and 70's where it clips to the underside of the floorpan between the fuel tank and rear end (called a surge tank?). Two or three years ago I purchased a 1967 4 door with 47,000 original miles on it, and all the paperwork going back to the purchase of it new. It doesn't have the white plastic surge tank, but the two hoses are clipped just behind the license plate, above to the left of the gas cap. They both had some kind of foam inserted into the hoses. Do you have the hoses up high, or do they sag lower than the top of the gas tank? I've been using this car as a daily driver and had no problem with gas leaking or splashing out of the vent hoses. John
Old Sep 4, 2011 | 12:12 PM
1967cutty's Avatar
i have the white piece on the end of the 2 hoses,and i have it runing to a bendable bracket above the license plate. I have a 4 door also.thanks......you wouldnt have any spare parts for a 4 door by any chance
Old Oct 20, 2015 | 08:10 AM
jcutlass70's Avatar
did you ever get fuel vent line figured out?
84oldsDelta88
20
Jan 12, 2016 01:36 PM
gearhead1218
Aug 10, 2010 08:18 PM
al714
Mar 17, 2010 09:43 PM
Wilson05
Body work
Mar 21, 2009 08:47 AM
70-442-455
May 22, 2008 09:34 PM
