Various trim levels on 66 442
Old Aug 9, 2019 | 12:26 PM
oldsnmopar's Avatar
I'm posting trim tag. I have been told 2 different things. I'd like agreeing comments that back up what my tag says please.
1966 442 trim tag
Old Aug 9, 2019 | 02:59 PM
What's your question, exactly? This is a Fremont car, so the 5V code doesn't appear on the cowl tag. There's no way to prove the car is a 442 without a build sheet. 3617 is an F85 Deluxe Holiday Coupe, and yes the RPO L78 442 option was available on that model. K C paint code says that it's a two-tone car with Ocean Mist lower and Provincial White roof. TR946 is a Turquoise interior.
Old Aug 9, 2019 | 03:06 PM
oldsnmopar's Avatar
Sorry. I was also trying to determine where the trans option was located?
Thank you very much for the info. I appreciate it.
Old Aug 9, 2019 | 03:08 PM
oldsnmopar's Avatar
I'm selling it, and I didn't want to mislead anyone. It was looked over and determined it is far more likely it's a 442. Original paint and parts, one fender was badly repaired but since corrected. Original fuel lines etc. Boxed arms. The normal replacement stuff too. But all the factory stuff is intact. Dual hangers. Clutch stuff. Etc.
Old Aug 9, 2019 | 03:11 PM
Unfortunately, unlike Mopars, Olds cowl tags provide precious little info. The only other item on that tag is the 02D, which indicates the assembly date as the fourth week of February. Non-Fremont tags from 1964-67 actually do have some additional option codes, but unfortunately Fremont didn't stamp them.
Old Aug 9, 2019 | 03:13 PM
oldsnmopar's Avatar
Thank you so much for your time and information. I appreciate it.
Old Aug 11, 2019 | 06:36 AM
Run to Rund's Avatar
There is one other small item on the cowl tag. The hole punched to the left of Body by Fisher indicates that the roof is prepared for shoulder belts. That is consistent with the date; Olds started doing this in Feb. 66.
Old Aug 11, 2019 | 06:53 AM
oldsnmopar's Avatar
Wow. That is interesting. Instead of making a code for it. That's very good knowledge. Thank you very much.
Old Aug 11, 2019 | 11:53 AM
I've seen that hole, but in the top right before. I'm sure that was a running change in mid year, so new codes would not be available until the next year's model.
In 67, they all got the mounts, regardless of if they got the belts. In Jan 1, 68, shoulder belts in hardtops were Fed mandate.
Old Aug 11, 2019 | 04:11 PM
oldsnmopar's Avatar
Thank you for that. I really appreciate everyone's valuable input. I'm selling it. So hoping a.lover of 442s will buy it. Price I posted is negotiable.
carsofchaos
Dec 27, 2024 02:45 PM
4+4+2=10
Sep 9, 2019 07:58 PM
toro455
Dec 8, 2017 02:01 AM
Jameskilcer
Oct 8, 2015 08:54 PM
bummerino
Mar 30, 2010 04:45 PM
