Valve guide seals/head gaskets Toro 425 B heads
Old Oct 4, 2024 | 07:44 AM
Slick66's Avatar
Slick66
Hi everyone, so what are my best options for valve guide seals and head gaskets? Much appreciated thanks.
Old Oct 4, 2024 | 06:24 PM
67OAI's Avatar
Old(s)GuysRule
Felpro top end set called "head set" is my recommendation. Has all the gaskets and seals (except intake gasket set) needed when pulling the heads. Be aware that the Felpro head gaskets are a bit thicker than the original steel shim head gaskets. Get the heads cut about 0.020" or 0.025" and it should go back together like original. Do not cut the intake side of the heads as that 0.020" or 0.025" cut restores proper geometry with the thicker head gasket.
Henrik
May 8, 2022 06:32 AM
Primus
Nov 1, 2019 06:34 AM
MDchanic
Feb 25, 2014 11:42 PM
KDW
Feb 10, 2014 10:30 AM
Redog
Dec 12, 2012 09:33 AM
