Valve guide seals/head gaskets Toro 425 B heads
Felpro top end set called "head set" is my recommendation. Has all the gaskets and seals (except intake gasket set) needed when pulling the heads. Be aware that the Felpro head gaskets are a bit thicker than the original steel shim head gaskets. Get the heads cut about 0.020" or 0.025" and it should go back together like original. Do not cut the intake side of the heads as that 0.020" or 0.025" cut restores proper geometry with the thicker head gasket.
azwildcats
October 1st, 2019 10:25 AM
Almond900
November 1st, 2016 09:29 PM
