Vacuum routing
Old Mar 22, 2023 | 11:32 AM
uncle dave's Avatar
71 Cutlass Supreme Conv
Vacuum routing
Good afternoon to all and Happy Spring. Can anyone help with a vacuum line routing question. The line that goes to the water valve should be a one with a white line on it. As per the vacuum diagram I have found on line. I do not have that line and I have two open ports on the heater control head. Everything else seems to be correctly run as far as I can tell. Just don't know which port to hook to the water valve. Any help would be greatly appreciated. Almost ready to fire it up for the first time. So much to put back together when you weren't the person who took it apart.
Sorry, it's a 1971 Cutlass Supreme Conv. BB
Old Mar 22, 2023 | 11:52 AM
Yes, white hose goes to the valve and to port #3 on the selector valve. Port #1 gets a vacuum source hose from the main vacuum harness. Port #2 is capped.
Old Mar 22, 2023 | 11:54 AM
uncle dave's Avatar
Thank you. It's the same picture I have found online but much clearer. Huge help.
Old Mar 22, 2023 | 11:55 AM
Once again, don't be cheap. Spend the money and buy a paper PIM.
Racecarguy1968
Feb 17, 2020 06:54 AM
bruneau
Jul 12, 2019 11:35 AM
BStone
Sep 6, 2011 04:55 PM
rhett838
Aug 25, 2010 07:01 PM
54olds
Aug 7, 2008 12:20 AM
