Trouble starting after seting 5 hours or more
I have a 86 olds with the 307, after I let it set for 5 hours or more I have to give it a shot or 2 of carburetor cleaner to get the fuel picked up so it will run but if it sets 1 or 2 hours its fine and will fire up first hit every time. Any help will be great. thanks
Thanks on the first start it will hit one good time and after that I have to hit it with the carb cleaner and pump the gas pedal and it will fire right up but if you don't ether put gas in the carb or hit it with the carb cleaner, it wont pick up the gas, after that its fine for the rest of the day, it will start first time with out any help, I can just stick my hand in throw the window and start it and don't have to touch nothing. but yea I'm going to check the chock take the housing off and spay it with some WD-40 and see if that helps. If I can get my lazy but out there to do it today. and thanks again patrick
SD72cutlass
December 7th, 2014 04:47 PM
gearheads78
October 19th, 2013 05:45 PM
