Transmission cooler lines
Old Sep 18, 2021 | 06:17 AM
arcflashfisher's Avatar
Good morning all. I need some help. I am putting my engine and transmission back in the car and can not seem to find any tranny cooling lines for it. It is a 1975 Delta 88 with a 350. Any ideas were I can find some?
Old Sep 18, 2021 | 06:49 AM
Vistabrat72's Avatar
If you are not going for a 100% original look, your local jobber store will have 5/16 - inch diameter lines with pre-made ends. These can be had in the very workable copper-nickel type material which makes them very easy to route and bend. Using some mechanics bailing wire, you can mock up the path taken by them between transmission and radiator to get the length you need. I am not sure if vendors offer ready made lines for the large Oldsmobiles, but, in all honesty, all engine/transmission and distance to the radiators are very close to one another over the various models of cars, and, with a bit of ingenuity, something slightly off can be made to work!
Bobby455
Feb 28, 2020 01:04 PM
jugdish
May 15, 2011 06:42 PM
dallasite21
Sep 29, 2010 03:32 PM
Hark442
May 1, 2010 02:30 PM
1973olds98
Mar 29, 2010 05:36 PM
