Traction off
Old December 18th, 2018, 06:49 AM
surupsamich's Avatar
Traction off
Ok I think this is an easy one for all the olds pros.
1995 regency elite traction off illuminates shortly after driving usually less than a mile. Goes out sometimes stays on most times. When the light is out the t/c button works as it should. Sounds like a wheel speed sensor from what I been reading but not 100% sure. There is something under. The hood labeled traction. I dont have a clue where to start any help?
surupsamich is offline
Old December 19th, 2018, 01:05 PM
Wash the wheels.
Koda is online now
Old December 19th, 2018, 01:59 PM
Hookers under Hood
76olds's Avatar
I agree with Koda, especially if you drive on country Dirt roads.
Also sounds like either a bad wheel bearing, wheel bearing sensor . Traction control disables itself when it senses a problem with any wheel sensor.
Hope this helps
Eric
76olds is offline
Old December 20th, 2018, 03:33 AM
T
Thanks koda and 76, although those conditions dont apply to my 98 now I can't say what the previous owner was up too. I'm also guessing you mean more than just a normal wash to the wheels. I'm going to pull all four and give the inner wheel wells and components a good cleaning. Good starting point. Thanks
Ronschwartzsr
June 30th, 2017 02:20 PM
Koda
April 20th, 2015 08:31 AM
DoubleV
Wheels and Tires
August 26th, 2014 12:07 PM
MaxDog
April 3rd, 2013 10:48 AM
coltsneckbob
Drivetrain/Differentials
September 9th, 2009 03:15 AM
Quick Reply: Traction off
