Touch up paint for 1957 Oldsmobile 88
Old Jun 6, 2025 | 07:17 AM
GLDN88's Avatar
Good morning, does anyone have a suggestion for touching up some minor chipped paint areas on my '57? The colors are 10-black and 60-alcan white. If possible, I'd like to do the touch-ups with a small paint brush. Thanks, David
Old Jun 6, 2025 | 07:21 AM
David, you need to go to a local auto body supply shop. They will have a natural UV lamp that they can use to sample the paint on your Oldsmobile and mix up a small tin of touch up paint for you.
Old Jun 11, 2025 | 06:31 AM
GLDN88's Avatar
Thanks Jesse, sorry for my late reply. I had a little trouble finding a local auto paint supplier. Finally asked the body repair shop that I've gone to for many years and they suggested a painters supply store. I called and took paint codes and they mixed up pint sized cans of acrylic enamel in two colors. What I learned in this venture is that base colors are water based and the clear coats are still solvent-based, but this will all likely change in the next few years (maybe 5 years). The anticipation is that environmental restrictions will make it so any paint application will be through a licensed facility and these auto paint suppliers will no longer sell to the public, not to mention the rapid increases in cost of materials and labor. I am sharing this for those of us who may wish to do touch ups or paint a panel, not the whole vehicle.
Old Jun 11, 2025 | 06:43 AM
Tri-Carb's Avatar
They really needed to mix it based on a scan of your car. The results of using color code numbers are sometimes not accurate for a particular auto.
Old Jun 11, 2025 | 06:51 AM
GLDN88's Avatar
You are absolutely correct. I chose to use the code as they said I'd need to leave the car with them for a few days and I did not have time to do so. The black color was fine and I think GM has used that code for most of half a century. The white was another story and I will need to have it adjusted or remixed. Thanks, David
Old Jun 11, 2025 | 07:09 AM
Did your car get repainted recently? If not the paint may be single stage instead of BC/CC.
Old Jun 11, 2025 | 07:19 AM
GLDN88's Avatar
It was repainted more than a dozen years ago and the previous owner could only tell me that it had been repainted. I am going to take the lift up door for gas into the paint supply store to see if they can get a closer match. I suspect it is single stage paint, maybe the paint store can verify this. Thanks, David
Old Jun 11, 2025 | 09:00 AM
If you bring in the fuel door they should be able to determine if it's SS or BC/CC. You can test this at home by using polishing compound on the paint. If your rag/applicator comes off with color you know it's SS paint. BC/CC will put a white or colorless film on your rag/applicator.
Dad-Par
Paint
Jun 22, 2021 09:05 AM
motojesus
Jun 28, 2019 03:52 PM
16Victor
Paint
Mar 10, 2016 07:06 AM
orsogrigio
21
Dec 13, 2015 02:51 PM
christl
Cars Wanted
Sep 18, 2009 10:22 AM
