Thread Sealant for Carb Fittings?
Old September 9th, 2020, 03:54 AM
4-Speed's Avatar
What thread sealant would be recommended for 66 Tri Carb fuel line fittings?
thanks
4-Speed is online now
Old September 9th, 2020, 05:45 AM
thanks
The inverted flare fittings get no sealer of any type. The seal is the tube flare compressed against the cone in the fitting. If the threads ever get wet, the flare isn't sealing and no amount of sealer will fix that.
The few NPT threads in the fuel lines (ie, the short nipple that goes between the tee fitting and 90 deg fitting on the center carb) can use a good teflon tread sealer. You're better off using teflon paste rather than tape, as small slivers of the tape can get dislodged when tightening the threads and end up in the carb needle and seat or other small passages.
joe_padavano is offline
Old September 10th, 2020, 03:15 AM
4-Speed's Avatar
Thanks Joe, appreciate your help-
Dave
4-Speed
April 16th, 2017 06:55 AM
joe_padavano
June 10th, 2015 06:03 PM
coppercutlass
May 10th, 2014 12:29 PM
scrappie
March 23rd, 2013 04:54 PM
RandyS
October 4th, 2012 12:36 PM
Quick Reply: Thread Sealant for Carb Fittings?
