Thoughts on Springs
Thoughts on Springs
I want to replace my front end springs. While I am at it I want to do all the bushings and ball joints. I can either pay to have it done or do it myself. I am extremely handy and pretty darn good at anything mechanical, but it is only me. How are spring replacements.
Would all I have to do is release the lower control arm to get the old out and new in? I figured I can jack front end up and support with several fixed jacks, then after spring is in compress it with my floor jack.....does that technic work?
Anyone have any technical tidbits/advice to share. Not concerned about purchasing correct tools. I have most already and getting more is not an issue. I really enjoy doing such things myself, but if too dangerous or if requires multiple hands or perhaps very expensive equipment (e.g. hydraulic lifts) then I would forego.....any thoughts?
fairly straight forward
Hey Bob, well the very least your going to need is a spring compressor, ( to do it safely), a ball joint fork, jack stands etc , I have heard guys using a floor jack, but never seen it done. I think you should be able to do it, I did mine, I would probably go with a whole front end rebuilding kit, they aren't that much in the scheme of things. You should have a chasis manual. if they are the original ball joints they are riveted on, the rivets will need to be cut off ( sharp chisel should work or an air hammer or grinder) others will chime in, but then you will be able to have all the parts detailed etc and you did it yourself, I think you should be able to do it.
http://www.youtube.com/watch?v=c1akq...layer_embedded
I posted this in another thread in the suspension forum... Much easier than a compressor.
thanks Ben..
I saw that you did it that way, and I have heard others do it I was trying to say I have never done it so didn't want to offer an opinion, I have to say the spring compressor wasn't bad but not what you would call easy ![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
but nothing ever is for me LOL....
I also replaced every thing myself. I used a spring compressor. Some parts stores have a free loaner with a credit card. I beat out the old bushings, and had the new pressed in at a local auto shop, $40.
On the jack, I went to a pawn shop and got a 2 Ton jack for $7 new.
bigjaythe1st
Suspension & Handling
May 8th, 2012 05:45 PM
1acesmith
August 11th, 2011 11:03 AM
