temp guage not working
Old Jan 24, 2016 | 07:02 AM
pacekar's Avatar
temp guage not working I can ground it out and the hand will move but if I hook it up to the temp sending unit nothing
Old Jan 24, 2016 | 07:12 AM
jaunty75's Avatar
Time for a new sending unit?
Old Jan 24, 2016 | 07:19 AM
pacekar's Avatar
I have put two in from autozone
Old Jan 24, 2016 | 07:27 AM
jaunty75's Avatar
That's the point here. Don't give us partial information. Give us the full story, not bits and pieces that we have to drag out of you. TELL US what you've already tried so we don't waste time suggesting things you've already done. Otherwise, you're just wasting everyone's time.
What kind of a car is this? Are you sure you're getting the correct sending unit? If it's a temperature gauge with a needle that moves as the temperature increases, that'll have a different sending unit than if it's just an on/off HOT light.
The fact that the gauge moves when you ground the wire at least indicates that the gauge itself apparently works and that the wiring between the sending unit and the gauge is intact. So this leads back to the sending unit as the problem.
Did the gauge work yesterday and suddenly stop working today? Or has it not worked for a long time and you're now trying to get it back to working condition?
Octania's Avatar
you realize a GAGE sending unit differs from an ALERT LITE sending unit, right? Got PN's handy? How about a nice used working or new GM unit?
Old Jan 24, 2016 | 07:42 AM
pacekar's Avatar
1969 hurst olds been off the road since 1991 rally gauges in it I rebuilt the motor used a manual guage to start the engine and drive it for about 500 miles decided to used the original guage
ELECMAN
May 24, 2012 05:54 AM
Finn5033
Apr 10, 2012 09:23 AM
Finn5033
Mar 24, 2012 11:57 AM
lmarquette
Mar 6, 2012 03:10 PM
toplessrocket
Jan 30, 2009 01:23 AM
