Steering column washer
Old Jan 19, 2021 | 08:45 AM
NotDads442's Avatar
I can't seem to get any help on the parts wanted portion of this site, so can someone tell me if the concave washer/disc and spring that holds the steering column bearing in place on a 67 Cutlass is Olds specific and or what other years will work?
Old Jan 19, 2021 | 04:23 PM
edzolz's Avatar
If you would read all of the parts wanted posts you would find the place to buy this part.
Old Jan 19, 2021 | 04:26 PM
NotDads442's Avatar
well since no one offered one up for sale I thought I would ask what other GM makes might use these and what years.
Old Jan 19, 2021 | 09:10 PM
edzolz's Avatar
As I said, read the parts wanted posts, you will find a vendor that sells this.
Old Jan 20, 2021 | 12:04 AM
66luvr's Avatar
Yes, all GM "A" bodies are the same on those parts. I recently ordered lower bearing from NPD's Chevelle catalog and installed it on/in a Olds 66 tilt floor shift column. I would assume non tilt column parts would also interchange with Our Olds.
I have a service manual for 66 olds and got the part number there, Googled the number and read the results which told it was a Chevelle part as well as other brands.
Good luck
Old Jan 21, 2021 | 12:08 PM
edzolz's Avatar
Do you want the light spring too? The one just under the washer.
Old Jan 22, 2021 | 10:39 AM
NotDads442's Avatar
Yes I need the light spring
Old Jan 28, 2021 | 01:29 PM
edzolz's Avatar
Putting in mail tomorrow. Thanks
Ed
Old Jan 29, 2021 | 09:12 PM
edzolz's Avatar
PM'd the tracking number to you.
Old Feb 2, 2021 | 04:16 PM
edzolz's Avatar
Tracking shows the item is in your post office box.
oldsrock
Jan 22, 2020 04:47 PM
oldsrock
Jan 19, 2020 06:52 PM
W-27
May 15, 2015 08:08 PM
72 98
Dec 1, 2011 07:38 PM
grt05
Apr 5, 2010 08:48 PM
