Steering column parts.
Old Jul 10, 2023 | 02:52 PM
Anyone in readerland have a contact or connection for someone that specializes in GM steering columns?
Many many years ago, I swapped a tilt column from a 75 cutlass into my 69. It was a very easy swap. I later found a turn signal lever that had the “set” button and used that with my aftermarket cruise.
I have since installed a later column in my car. I still have most of the parts from the 75 column.
The time has come to build a column for my sons 71 el Camino. His plans basically follow mine from years earlier. We got a tilt column from a 75ish Pontiac Grand Prix, thinking it would be the same as the column I used from the Olds. Not even close!!
I have a huge tote of column parts, I’m finding out not all columns are the same. I’m not exactly sure what I need, I’m hoping someone that specializes in this stuff can help with the right parts.
Old Jul 10, 2023 | 06:33 PM
2blu442's Avatar
Matt, since your in Indiana you might reach out to Scott Winn who goes by oldspackrat here on Classicoldsmobile.
John
Old Jul 10, 2023 | 07:30 PM
John
Where do you think I got the column? 😁😁😁
I knew it wasn’t a Olds column, I ASSUMED since they came from the same vintage car, they columns would be identical other than the brand specific items (steering wheel, the styling of the turn signal/tilt levers) I’m finding that’s not the case.
Old Jul 11, 2023 | 06:28 AM
https://www.steeringcolumnservices.com/
Old Jul 11, 2023 | 02:28 PM
Once again, Joe has the answer.
Real82it
Jul 11, 2022 12:08 PM
willj
Jun 22, 2022 11:12 AM
Kidcutty
Jan 19, 2010 06:35 AM
70redvert
Dec 10, 2008 08:30 PM
souldoubt1
Nov 6, 2005 10:22 PM
