Tilt Steering column swap
Old Dec 10, 2008 | 11:36 AM
70redvert's Avatar
My project car is a '70 convertible floor shift, with a black steering column. My parts car is a '70 Supreme hardtop column shift, tilt wheel, & cruise control on the blinker handle with a gold steering column.
What I would like to know is, can I take the gold column with tilt and just use the part of that column on my black column? I am trying to avoid using the bottom half of gold steering column because you would see where the column shift handle was pinned in.
Sorry but I think I confused myself too.
Greg
Old Dec 10, 2008 | 11:44 AM
Are you trying to convert to tilt?
Old Dec 10, 2008 | 11:46 AM
70redvert's Avatar
yes
Old Dec 10, 2008 | 11:49 AM
I have always replaced the whole column.
Old Dec 10, 2008 | 11:54 AM
70redvert's Avatar
What do you do with the column gear shifter mounts?
Old Dec 10, 2008 | 11:58 AM
What I have always done is use a floor shift tilt column.
Paul at ROS
parts out A bodies in CT he usually has used ones
203-272-7103 [after 6:00 p.m.]
ros@hotmail.com
Old Dec 10, 2008 | 12:03 PM
70redvert's Avatar
Thanks.
Old Dec 10, 2008 | 01:46 PM
gutlesscutlass's Avatar
I think you can also purchase just the collar and replace it with one for a floor shift.
Old Dec 10, 2008 | 01:50 PM
70redvert's Avatar
I can look into that. Are they new?
Old Dec 10, 2008 | 02:44 PM
easytobedead's Avatar
Just A BaBy {:
i have that on my 85 an i don't like it.i am just going to replace the hole thing.
Old Dec 10, 2008 | 03:01 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Send 2blu442 on this board a PM. He probably has what you need. I bought a tilt column shift for my 72 Cutlass from him. John is a good guy, staight shooter and his prices are fair.
Old Dec 10, 2008 | 08:30 PM
The part you need is called a "shift bowl" and it is different between tilt and non-tilt columns. The good news is that the shift bowl can be changed from column to floor shift models. I don't know if you can buy them, but the upper part of the GM column is the same well into the 1970s and early 1980s, so you can usually score a cheap shift bowl from a Camaro (for example).
starfire
Dec 9, 2021 08:21 PM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
ELECMAN
Jan 22, 2012 01:49 PM
ros6872
Feb 24, 2010 05:50 PM
