Steam coming from Driver Side valve cover breather
Hey! Just got me a 78 olds cutlass. I was messing around adjusting the carb to get it to idle right and I noticed steam coming out the driver side valve cover breather. The car was sitting for 5 plus years. What could this possibly be and where does that route to? Mindful advice appreciated.
If the oil is clean, and it’s not using antifreeze, I’d drive it awhile before doing anything. Make sure the coolant is topped off, make sure the oil does t look like a chocolate milkshake, and take it out for a long drive on the highway. You need to get it hot enough to boil off any accumulated moisture. Once you are done with the drive, check the oil again, if it’s good wait for the engine to cool off and check the coolant again. If it’s still full, relax.
HighwayStar 442
September 5th, 2017 09:15 PM
Almond900
February 26th, 2016 02:56 AM
