Steam coming from Driver Side valve cover breather
Old Mar 23, 2023 | 10:23 AM
AdrianHaley's Avatar
Hey! Just got me a 78 olds cutlass. I was messing around adjusting the carb to get it to idle right and I noticed steam coming out the driver side valve cover breather. The car was sitting for 5 plus years. What could this possibly be and where does that route to? Mindful advice appreciated.
Old Mar 23, 2023 | 10:31 AM
Are you sure it's steam and not oil smoke? In any case, it would not be unusual for condensation inside the motor to vaporize once the engine warms up.
Old Mar 23, 2023 | 10:37 AM
I don’t think so. It don’t smell like oil
Old Mar 23, 2023 | 10:42 AM
He also did say it had mad water accumulated on the engine but I’m honestly stumped. I’m tryna figure out if it’s blown or not so I can go ahead and drop something else in it
Old Mar 23, 2023 | 11:19 AM
Does the car run well besides smoking/steaming out the valve cover breather?
Old Mar 23, 2023 | 11:20 AM
Yes. It runs. There’s no smoke coming from the exhaust either so I’m honestly confused lol.
Old Mar 23, 2023 | 11:36 AM
If you're concerned then do a compression test.
Old Mar 23, 2023 | 11:37 AM
I’ll give that a try and I’ll keep you updated on it
Old Mar 23, 2023 | 11:59 AM
Is the PCV connected to one of the valve covers?
Old Mar 23, 2023 | 01:39 PM
Engines will smoke and steam after sitting for years. This is not a reason to go Chevy.
Old Mar 23, 2023 | 02:02 PM
70W-32's Avatar
Did you change the oil when you got it? 5 year old oil would be crap, even if the car hasnt run in that time
Old Mar 23, 2023 | 02:29 PM
I would run it for a while and see if it clears up. It can also be blowby.
Old Mar 23, 2023 | 02:35 PM
There is never a reason to go Brand “X”.
Old Mar 23, 2023 | 02:38 PM
If the oil is clean, and it’s not using antifreeze, I’d drive it awhile before doing anything. Make sure the coolant is topped off, make sure the oil does t look like a chocolate milkshake, and take it out for a long drive on the highway. You need to get it hot enough to boil off any accumulated moisture. Once you are done with the drive, check the oil again, if it’s good wait for the engine to cool off and check the coolant again. If it’s still full, relax.
REO442
Dec 17, 2022 07:37 AM
Donaldbabineau
Jan 2, 2022 04:05 PM
HighwayStar 442
Sep 5, 2017 09:15 PM
Almond900
Feb 26, 2016 02:56 AM
defiant1
Mar 23, 2011 07:50 PM
