Starter motor heat sheild ??
Hi All, iam looking for a diagram or picture on where to install this type of heat shield for our 1969 455 that's in our 1967 442 car, Here it is on eBay, looked for ever last night found one that comes off the motor mount, this is the one i would rather have, I removed one like 35 years ago and there's no way i can remember that, Thanks to anybody out there that has some type of photo on where this goes thanks so much john...............
1964-77 Oldsmobile Cutlass / 442 Starter Heat Shield And Brace
https://www.ebay.com/itm/351152351058Last edited by Olds64; August 15th, 2023 at 10:53 AM.
No link. Is this the starter shield you were asking about?
https://www.ebay.com/itm/195907304655
I wouldn't use one of those as it's universal.
That "heat shield" replaces the normal starter strap between the starter motor and the block, using the same bolts as the strap. To be honest, I'm skeptical of starter heat shields. The shield doesn't prevent the passage of heat, it only delays it. At some point the shield is at the same temperature as the exhaust manifold, and the starter sees the same temp it would have without it. Worse, once you turn the engine off, the shield holds heat in the starter, keeping it warmer for a longer period of time pending restart.
WOW !! Thanks Joe p I always can count on you, i will pass on it then, Long story short i went with the Robb Mc mini starter motor, and used all 0 gauge welding cable from the trunk all the way up to the horn relay, and even from the horn relay down to the solenoid, And 0 Gauge for the negative trunk to frame, The car runs around 180-190 degree's sometimes when it gets hot it gets stubborn, i was thinking of something that could help it, thanks joe, P/S Thanks for the diagram's to..... John.............
I'm going to beef here. We are not certain that the starter heat shield is the same temp as the exhaust pipe. At some point, the heat in the exhaust and the ambient air will reach an impasse, and that pipe will be as hot as it is going to get. The starter heat shield will absorb a portion of that heat rate, and, at some point, will get as hot as it will get, but I do not believe those two temps are the same. I also do not think the cooling time is increased with a shield that touches at only two points to an appreciable degree.
Makes you wonder if the OP wants a starter heat shield because it's so SHINY (I'm guilty of this in the past)? Or does he have a hot no-start condition?
Oldsguy and my late mother told me stories about the hot no-start condition Oldsguy's 71 Cutlass S had 35+ years ago.
Is a hot no-start because of a poor quality starter, misadjusted timing or something else? FWIW, I have long tube headers on the 455 in my 71 98 and I've never had a hot no-start. I did have a starter blanket for awhile. It was pretty SHINY in that Summit or Jegs catalog though.
Yeah, it was the classic starter heat related problem caused by headers. Back then we didn't have the inter-web at our disposal to find racing realated equipment such as mini-starters or high performance stuff. Sure it was out there but not as easily available. That car would decide not to start at the most inoportune times, quite embarassing.
synoptic12
May 29th, 2022 08:19 AM
