SS II Wheel Project
Old Oct 24, 2010 | 01:36 PM
pplatamone's Avatar
A72CUT
Post SS II Wheel Project
I am done with a set of restored stock SSII (14 x 7) wheels for my 72 Cutlass Supreme and now want to mount a set of tires.
Looking for some input and opinions:
Like BF Goodrich TA Radials with the tread pattern that was popular in the early to mid 70's but so far dont think they still make this item. If anyone has any input I am open to suggestions.
If not TA's can anyone suggest an alternative that they like?
Can anyone provide me some input on the largest size tire I can mount on the 14 x 7 SSII wheels and not have any clearance issues with my Cutlass wheel wells?
Thanks in advance for any input.
Regards,
A72CUT
Old Oct 24, 2010 | 02:57 PM
Well, unfortunately, the number of 14" tires available today is somewhat limited, and the largest ones you can get will not be a clearance problem. 245/60-14s are the widest BFG T/As still available in 14" and they fit with no problems. They are also only 25.5" in diameter, which is a little too small for my tastes in an A-body wheel well. 225/70-14s are about 26.5" in diameter and fill the wheel openings a little better, but are narrower. These also clear with no problems. I don't think 235/70-14s are readily available anymore, but if you can find them they will also fit fine. Your call.
Old Oct 24, 2010 | 04:35 PM
pplatamone's Avatar
A72CUT
Hey Joe,
Thanks for the great input!
Paul
Old Oct 25, 2010 | 05:01 PM
TripDeuces's Avatar
Ha, and you called my avatar creepy!
Old Oct 26, 2010 | 08:28 AM
Jon69's Avatar
tirerack.com lists BFG TA 225/70/14 in stock $356 for a set of 4.
Or if your looking for something wider they also list 245/60/14 in stock for $416 for a set of 4.
oldstofty
Jun 3, 2019 03:46 PM
CutlassS1972
Body work
Aug 21, 2014 09:06 PM
TheBiggness
Mar 8, 2007 05:27 AM
65culassholiday
Jul 9, 2006 11:36 AM
<NickC>
Nov 10, 2004 01:32 PM
