Spoiler Installation Per 1970 Assembly Manual
Old Mar 12, 2019 | 11:39 AM
stlbluesbrother's Avatar
For anyone interested, this screenshot was taken from the 1970 A-body Assembly Manual. I would expect the same installation for 71 and 72, too.
Old Mar 13, 2019 | 03:42 PM
shiftbyear's Avatar
I wonder if the holes were pre-punched on the assembly line trunk lids or did they hand drill with a template? Would the pre-punched trunk lid have a separate part # ?
Old Mar 14, 2019 | 05:15 PM
anthonyP's Avatar
If the factory and over the counter spoilers had two studs on each pedestal to mount the spoiler to the trunk, and one stud in each pedestal to secure the wing, then why does the image seem to show three holes in the trunk lid where the pedestals align? Possibly a change from three mounting studs in each pedestal to only two after the assembly manual was published?
Old Mar 14, 2019 | 05:47 PM
oldolds88's Avatar
look at the inside of the hole,ragged= drilled neat smooth = pierced.
Old Mar 14, 2019 | 05:52 PM
billrob71's Avatar
Here is a GM pic and shows 3 holes with the measurements
ere is
Old Mar 14, 2019 | 06:01 PM
anthonyP's Avatar
Does anyone have a spoiler equipped car with documentation who can say if the trunk lid has three studs on each side mounting the spoiler? It seems at least the dealership over the counter, and Demmer Tool & Dye spoilers given to employees, only had two mounting studs in each pedestal.
Old Mar 15, 2019 | 04:00 AM
shiftbyear's Avatar
I agree with what you are saying but I've never had the opportunity to see a factory trunk lid with a spoiler up close from the underside. Can someone post a picture? Also are the torsion rods thicker or placed differently to allow for the extra weight of the spoiler? Thanks
Old Apr 2, 2019 | 05:08 PM
DROLDS707172's Avatar
Spoiler
I thought the original " wings" that were installed from GM had 3 mounting studs per pedestal. The middle stud actually screwed to the top of the wing , so when you tightened it down, it forced it against the pedestal. I have both an original wing with the 3 studs and a reproduction with the 2 studs per side. The 2 stud repo seems to loosen up and you can rock the top of the wing back and forth. The original is always nice and tight!
Old Apr 3, 2019 | 08:56 AM
friesjh's Avatar
I am very curious about this as well. My black 71 originally came with a wing. I've known about the car since 1985. It's had the same wing on it since I've known about it. It has 2 studs on each side. It may have been replaced between 71 and 85, but it's heavy like the OEM wing. Not very light like the reproduction wings.
@Shiftbyear - The springs must be different. I know when I pop the trunk on the above mentioned car it opens by itself and that wing is fairly heavy. I have always heard they used heavy rated springs.
Old Apr 4, 2019 | 08:52 AM
anthonyP's Avatar
If anyone has access to their Rallye, would they please check to see if there are three or two mounting studs for each pedestal in the trunk lid. These should be factory installed, though possibly not on the regular production line as early cars were supposedly pulled off the line then converted to Rallye 350's. **
The later Rallye's might have been assembled on the regular production line if ordered by the dealer for their inventory or a customer.
Maybe the earlier produced spoilers had three deck lid mounting studs per pedestal and later two due to a design change? How many mounting studs are on an OEM '69 Hurst/Olds spoiler?
Was the trunk torsion bar different for factory spoiler equipped cars, or was the torsion bar mounted differently to increase the tension?
** Just looked at the revision dates on the manual drawings and all are well after the start of production. The revision dated December 1969 notes the center stud was a bolt, which is on my brother's spoiler bought over the dealer counter in 1971. The February 1970 revision adds an additional measurement for drilling the trunk lid holes. A Rallye with a January 1970 build date has a spoiler with two mounting studs in each pedestal.
Old Apr 8, 2019 | 07:48 AM
anthonyP's Avatar
Rallye 350 with 3rd week of March build date has three deck lid mounting studs per pedestal.
Rallye 350 with 3rd week of January build date has two deck lid mounting studs per pedestal.
Old Apr 8, 2019 | 08:04 AM
dragline's Avatar
Can anyone submit a picture of either? Thanks
Old Apr 8, 2019 | 09:32 AM
Wing
Then all 1969 Hurst's would have 2 studs?
Old Apr 8, 2019 | 10:53 AM
anthonyP's Avatar
Hopefully someone with a '69 Hurst/Olds can chime in about those spoilers and the number of deck lid mounting studs in each pedestal.
Does anyone know if Demmer Tool & Die made all the 69-71 spoilers or just the early ones? We're the spoilers manufactured in-house at some point? If so, that might explain why some OEM spoilers have two trunk lid mounting studs in each pedestal and others have three.
Old Apr 8, 2019 | 10:58 AM
anthonyP's Avatar
Old Apr 8, 2019 | 11:16 AM
Wing
Middle looks like a longer stud, just like on mine
Old Apr 8, 2019 | 11:23 AM
My late 69 H/o had 3 holes on each side
Old Apr 8, 2019 | 12:20 PM
Hairy Olds's Avatar
Shoveling Snow
All of the spoilers were made by demmer in early 69 or late 68.
Old Apr 9, 2019 | 07:34 PM
shiftbyear's Avatar
So what's the synopsis? Was there a cutoff date for the 2 hole spoiler? Were the trunk lids pre-punched or template drilled? Are there any records or engineering drawings showing the different configurations? How did they avoid confusion on the assembly line? Torsion bar requirement? Were the trunk lids painted with the spoiler attached? How do you spot a fake?
Old Apr 12, 2019 | 12:17 PM
anthonyP's Avatar
Are you saying all of the Hurst/Olds spoilers were made Demmer in early 69 or late 68? Or do you mean all of the spoilers were made at that time for the 69-71 cars, and were all made by Demmer?
Old Apr 12, 2019 | 12:46 PM
anthonyP's Avatar
So it looks like the '69 Hurst/Olds may have all had the 3 trunk lid mounting studs in each pedestal. Maybe someone else with a '69 Hurst/Olds can also verify their car spoiler is the same. This sort of contradicts the 1970 assembly manual which shows a January 1970 revision stating the center bolt was changed to a mounting stud.
My brothers OEM spoiler has the center bolt holding the wing to the pedestal and it was purchased over the counter in late 1971. Could it be the spoilers held in inventory for distribution to part departments for over the counter sales all had the two studs per pedestal, and all those installed by the factory or by Demmer during conversions have the three studs per pedestal?
Does anyone have a 1971 car that has a factory installed spoiler and can check the number of trunk lid mounting studs for each pedestal are present?
Demmer must had made the spoilers with two trunk lid mounting studs per pedestal at some point since at least one was sold over the counter that way in 1971, and the two for sale on this site that are original Demmer made spoilers with two trunk lid mounting studs in each pedestal that were given to it's employees.
scrappie
Feb 7, 2018 06:56 AM
Cincinnati Rick
Jan 15, 2015 02:31 PM
eric72
May 4, 2010 08:22 PM
Hairy Olds
Oct 31, 2009 12:47 PM
