Roof rail weatherstrip install
This is on a 69 442 Hardtop. Is there any trick to installing the Roof Rail WS (SofSeal)as it goes around the plastic window guide at the front corner of the roof rail and pillar. I test fit it yesterday and it seemed to be in a little bit of a bind as it went around the guide. This may be normal. I thought it might fit completely under the guide, but that did not look right at all. By that I mean putting the upper part of the seal (that fits on top of the window) under the guide also.
If I just keep the seal in the channel all the way around the guide, it fits fine but it justs has a little bit of an indention as it goes around. Any tricks or special way to do this?
Last edited by rsandhoff; April 15th, 2009 at 08:58 AM. Reason: Needed to list type of car
Looks like you never got an answer to this question, or,did you?
I have the exact same issue on my '72. Its never had a decent weatherstrip, so I have no reference for my new one. One thing I know is, it isnt just stick it in with some sealant like so many people's experiences here.....
Any help would be great!
There is a channel for the weather stripping to install into and that needs to be cleaned out. Any old material in there including adhesive will affect the fit of your new weather strip. Yes you are supposed to use an adhesive to bond it to the metal - like 3M weather stripping glue. Just one thing though. The new weather strip may have mold release agent (from production) in small quantities. Clean or rough the bonding surface lightly with a cleaner or 80 grit sandpaper to ensure adhesion. Most of the weather strip kits for A bodies are easy to install.
If your weather strip around the roof rail needs replacing you probably need it all the way around the car, (doors, trunk) and likely need new quarter glass rubber too. All those changes will seal the car up nicely from elements and reduce road noise. How are the window fuzzies?
I did all exactly as you say, Allan. Cleaned out the old w.strip completely, used the 3M 8008 weatherstrip adhesive, and ran it in the channel. Oh, I didnt rough it up, too late now I guess. It was a no brainer, except where it makes the turn from the pillar, to the roof, it dosent look right behind that guide thing. It also seems to be too large for the two clip things. I have to squish them quite a bit to get them into the clips. I am looking everyday for an olds, so I can compare.
I replaced the door panels, inner & outer door glass weather strip, door weather strip, quarter glass strips, and have yet to install the trunk weather strip.
I feel at a disadvantage with my ride some times. So much of my car was dismantled years ago, and I have to figure every little thing out. Gets frustrating. Im glad I found this site.
Wow, mine looks simular, but bigger. My seal is larger. Thats why its squeezed into that same clip I see in your photo. I checked the package from Soft Seal, looks correct, but its different from yours. now I have to figure out how to post the pic......
I probably should tell you that the weather strip in that picture is genuine OEM. It was installed in 1986 and is still going strong. That may be why your soft seal stripping looks slightly different.
I just drove my Olds 30 miles to a car show (a car show that last year had 3500 cars turn out, but I only found 3 Oldsmobiles), with my "new" weatherstripping howling the whole way.
I would really like a weatherstripping expert (whoever he may be) to chime in with info that helps us with crusty old crap, that needs to be replaced. Brand names & part numbers!!
Anyway, by the time I figure this all out, that expert may be me.........
Maybe cut at a 45 degree angle from two dirrections and glued back together?
Nope....Ive just left it like it is. Ive seen a few now, & my WS is the only "fat" style I've seen. So, Ive decided Im going to replace it, with the o.e.m. kind like in Allan's pictures (if possible), but I want to see it before I buy it now...... so I'm gonna wait til I see those Soft Seal guys at the next car show.
I never could get a pic on here of my situation. Im gonna try again.
TrackDay
March 5th, 2013 07:08 AM
