Ring gap
Old Jun 3, 2024 | 10:04 AM
krypotonique's Avatar
Ring gap
I am putting together a 455 bored .40. ( 4.165.) I am installing a silvolite cast piston .40 10:1 how do i figure the ring gap? hasting steel molly rings 2m 661 040
thanks
Old Jun 3, 2024 | 01:03 PM
442Harv's Avatar
No info on the box the pistons came in? If not, call the piston company, and ask what they recommend.
Old Jun 3, 2024 | 04:11 PM
The old rule of thumb is “.003-004 per inch of bore”.
4.165x .004= .016666. Obviously, if the ring or piston manufacturer specified something different if use their recommendation.
Old Jun 4, 2024 | 12:55 PM
thanks for the info
Old Jun 4, 2024 | 06:40 PM
BillK's Avatar
K,
Those rings are standard gap rings and should be fine just the way they are as long as the bore is exactly .040" oversize or slightly bigger. Silvolite cast pistons do not require any type of unusual gaps.
jskorz
Jul 16, 2021 05:20 AM
bigdan1
Jun 17, 2021 03:21 PM
Jhucks03
Apr 5, 2019 05:40 AM
pogo69
May 19, 2014 01:50 PM
sx455raidercelticfan
Jan 13, 2011 05:05 AM
