Rear quarter power window binds/stuck
Old Jul 31, 2022 | 08:25 AM
Moegs's Avatar
'70 442 The motor hums and the window struggles to open or close. How difficult is it to get to the mechanism and troubleshoot?
Thanks for your help!
Old Jul 31, 2022 | 10:34 AM
Charlie Jones's Avatar
Phantom Phixer
Remove the rear seat.
Remove the trim panel.
Pull the access panel on the body sidewall.
A 1970 Fisher Body manual is also very helpful when repairing power windows.
1970 fisher body manual: Search Result | eBay
Old Jul 31, 2022 | 12:42 PM
Often when this happens it's due to a broken plastic window roller. Also, lubricate the tracks with silicone grease.
Old Jul 31, 2022 | 06:35 PM
Moegs's Avatar
Removed trim and access panel. Window is stuck in down position. Using flashlight, it's obvious there's roller that's totally buggered up. I do have a '70 Fisher body manual. Looks like I will have to remove the window channel assembly. Manual says to have the window half way up, or am I missing something? Any tips on removing the assembly? Forgot to mention it's a convertible, but that shouldn't matter, should it?
jarcher442
Dec 29, 2021 05:08 PM
H70 Olds
Aug 8, 2021 06:06 PM
firstoldsmobile
Body work
Dec 17, 2020 04:37 AM
792drdelta
Aug 8, 2013 10:42 PM
shakeyhands73442
Feb 1, 2013 12:05 PM
