Questions...turnsignals....fanblower
Old Dec 23, 2011 | 09:23 AM
65OldsDelta88SuperRocket's Avatar
Hi!
I have two questions.
1. The interior fan for the heat/vent/ac is making a horrible noise when its on low medium or high. Sort of like a high pitch squeaking scratching noise. What needs to be replaced? For now I pulled the wire in the engine bay to the blower....but without heat im freezing!
2. My turn signal shaft/stick completely broke off. It there an easier way to wire a different switch to it so I can use my turn sigs or do I need to somehow reattach the stick?
Old Dec 23, 2011 | 09:40 AM
Lady72nRob71's Avatar
Sounds like the fan motor bearings are dry or rusted. Motor prolly needs replacing.
Old Dec 23, 2011 | 09:54 AM
http://www.ebay.com/itm/GMC-Volvo-Bu...item48433cfe35
is the the correct part u think?
Old Dec 23, 2011 | 10:00 AM
firefrost gold's Avatar
my 66 pontiac broke off too I just removed the wheel and replace the turn signal parts
in the column know it auto cancels and everything was not a big deal price or effort.
Old Dec 23, 2011 | 10:01 AM
Rickman48's Avatar
I've gotten away with drilling a 1/8" hole in the nub if the blower motor, squirting some WD-40 or better lubricant in the hole, and sealing it with wax.
Works for a season or two!
If you've got easy access - it works, but if you've gotta pull things apart, spend the $40-50 and replace it!
Think they might be cheaper at your local auto parts store - they're still available!!
Only fix on the turn signal is replacement = try to find a Delco auto parts store - cheaper!
Old Dec 23, 2011 | 10:04 AM
oh la la that jerry rig sounds doable.
Thank you
Old Dec 23, 2011 | 06:58 PM
No - way too new.
Rockauto has them. FOUR SEASONS Part # 35587 for a whopping 22 bucks.
Treat yourself to a new one!
Eirik
Sep 22, 2006 08:26 AM
hrazor35
Sep 17, 2006 06:45 AM
tarps3
Aug 11, 2006 03:35 PM
shirleys_cutsey_classic
Mar 9, 2006 01:10 PM
