Question on crank case ventilation
Old Apr 4, 2009 | 05:39 PM
Snowdog's Avatar
I have a 65 cutlass with a 330. 45.000 miles, Had the upper end redone.
It is blowing oil out of the oil fill tube not much but thats
what it did before I had it done. Pvc valves did not exist then
The CVS works with original parts is connected . Is there a way
to stop this or convert it to a PCV.
Kevin
Old Apr 5, 2009 | 05:15 AM
Kevin
Install a later valve cover with a grommet for the PCV valve. Plumb the valve to manifold vacuum. Be sure the breather cap is vented. Done.
Old Apr 5, 2009 | 07:16 AM
Snowdog's Avatar
Where would it connect to the manifold?
The old CVS connects to the rear of the carb.
via a vacum line
Old Apr 5, 2009 | 10:09 AM
via a vacum line
Any source that taps directly into a manifold runner or the base of the carb. Typically this would be something like the power brake attachment. If your carb has a barb fitting that is manifold vacuum, that's fine.
Old Apr 7, 2009 | 03:28 AM
Yellowstatue's Avatar
Smile Fresh air
'64 and '65 Cutlass had PCV valves!! PN 6420092 type 639 for V8...PN 6421971 for V6..you had me wondering there for a while, must have been a trick question.. Also the valve cover should hook into the air cleaner via a metal tube and a couple of gromets according to the parts book..
Old Apr 11, 2009 | 03:35 AM
Snowdog's Avatar
Need Air
The only hook up is from valve cover to air cleaner via a tube
with a A/C Delco part ( a little roundish piece with a flapper inside)
between the two, that part hooks to the rear base of carb.
No other holes in valve covers.
Old Apr 11, 2009 | 11:43 AM
Snowdog's Avatar
Here is the pics
Only hole in the valve covers is the CVS.
boese1978
Jan 29, 2013 12:31 PM
chasman414
Oct 4, 2012 03:21 PM
68Tom
Nov 8, 2010 02:14 PM
jensenracing77
Sep 4, 2009 05:39 PM
iuhoops83
Aug 2, 2007 11:22 AM
