QUESTION: 1994 Cutlass Supreme 3.4 vs 3.1 resonator use
Old Dec 14, 2022 | 06:00 AM
BlueCalais79's Avatar
Quick question, if I can get the tip customized, can I use the 3.1 Wagner resonator/pipe that runs from behind the cat and have a Y pipe welded on that will then route to the 2 mufflers?
I have the NOS left side muffler, but at this point I waited too long to buy all this stuff, no RH will be available, and the AP Mufflers 700444 and 700355 are no longer being sold. I needed to go custom anyway since I'm getting the ADDCO 474 rear sway bar installed and the exhaust/mufflers would have needed to have been modified for clearance to fit that bar.
I can still get a Wagner resonator for the 3.1 motor and if this somehow can be used, things will be a heck of alot easier the rest of the way.
Thanks one and all, and if anyone would know what mufflers I can get that would be great. I would much to prefer to get the 2 dual tips, if that can be done.
Old Dec 14, 2022 | 09:46 AM
Externally, the 3.1l and 3.4l are the same. If you can't get OE parts for your car with the 3.4l, why not just use aftermarket parts? Most exhaust shops have a house brand muffler/resonator that will work just fine and save you money.
Old Dec 14, 2022 | 01:33 PM
I'm hoping to get away with getting exhaust tips the will resemble the factory units, after that you are on the money in that I'll more than likely go with what a Muffler shop can build under there.
Old Dec 15, 2022 | 04:29 AM
Keep us posted.
Old Dec 15, 2022 | 08:13 AM
Will do, I hope to get with the shop next week. One of the support brackets rusted off and when I took a good long look at the whole system, I know now I'm on borrowed time.
george landis
Suspension & Handling
34
Jul 23, 2022 05:04 PM
bk82388
Oct 30, 2018 06:15 AM
Al Graaf
Mar 17, 2012 08:05 PM
B-Mann
Apr 6, 2010 03:49 PM
amrcnmscle
Dec 17, 2008 06:53 AM
