pump
pump
hi,i would like to change the ugly power sterring pump that is on a '66 88.i notice that on later 455's,the newer pumps are mounted lower and out of the way.i should be able to do this mod no problem right?,i was even thinking of looking at the remote pump and reservoir as per my '87 regal.any thoughts please as i don't think anybody has done this.
One more thing. Don't forget the two spacers between the pump brackets and the block on the 68-up bracket configuration, HOWEVER, be aware that the spacer between the lower rear bracket and the block on the 1965-70 full size cars is different from the normal one seen on Cutlii. This is because the 65-70 cars use the forward motor mount location on the side of the block, so the lower rear bolt for the PS pump bracket is the same one that holds the front of the motor mount. The spacer for these cars is thus thinner by the thickness of the motor mount flange that it sits on.
Nor Cal Andy
March 29th, 2012 07:27 PM
