Pro Products Harmonic Dampers
Old May 16, 2013 | 04:00 PM
joepenoso's Avatar
Question Pro Products Harmonic Dampers
I bought a PROFESSIONAL PRODUCTS HARMONIC DAMPER for my 455 Olds.It sure looks pretty with 0-60 degree marking and every 90 degrees another line is placed.
The motor is stock and I am wondering if the engine is internally balanced or externally?
It comes with a small counterweight bolted inside the damper that can be removed for internally balanced motors.
It also mentions a special tool to install damper to crank?
Do you need it?.
thanks
joepenoso
Old May 17, 2013 | 07:20 AM
joepenoso's Avatar
Anyone?
Old May 17, 2013 | 07:38 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
stock is externally balanced, and yes , use the tool. If you beat those on with a mallet it could break the vulcanizing
Old May 17, 2013 | 08:15 AM
ALL 1964-1990 Olds V8s are externally balanced. The internal/external thing is from the Chevy-centric world. Unless you have a custom-balanced rotating assembly, keep the weight.
The real reason why you want to use the proper tool for installing the balancer is that if you hammer it on, you run the risk of damaging the thrust bearing inside the engine.
Old May 17, 2013 | 09:05 AM
Octania's Avatar
Damage the thrust bearing? Huh.
The correct tool draws the damper in place slowly with screw threads in the crank snout. Smooth and easy.
Trying to envision someone hammering one in place.
The term "hammer mechanic" comes to mind
*caveman grunt*
BANG!
Rrrrrrgh!
Old May 17, 2013 | 09:23 AM
bccan's Avatar
I "pounded" quite a few balancers on back in the day & never noticed any ill effects. Always made sure surfaces were clean, lubed them up w/ whatever was handy - oil, WD, silicone. Hold a piece of wood against front, usually contacts the raised ring that many have around the opening & used only as muchy force as it took.
That said, I did eventually buy the correct tool probably 20 years ago & it is a much better way of installing a balancer!
Old May 17, 2013 | 03:24 PM
joepenoso's Avatar
Thanks a lot I'll buy or rent the tool
joepenoso
Old May 17, 2013 | 07:17 PM
rjohnson442's Avatar
Mr. Johnson
X2 on the bang bang method. I've been known to do it a few times myself. But I do have a remover and an installer now also.
Old May 19, 2013 | 07:52 AM
joepenoso's Avatar
Question
Approximately how much is the installer tool?
joepenoso
Old May 19, 2013 | 08:40 AM
joepenoso
1) Go to Google.
2) Type in "harmonic balancer installer" (without quotes)
3) Revel in the wide variety of prices.
dlh61olds
Dec 15, 2014 12:30 PM
Al Graaf
Apr 9, 2012 10:33 AM
rocket731
Sep 5, 2009 10:18 AM
Want-A-Vert
Mar 7, 2007 12:34 PM
