Power Steering
Old September 9th, 2014, 08:43 AM
rickbmac's Avatar
Power Steering
Restoring a 1972 Cutlass with 350.
Moved my power steering pump to opposite side of engine with newer bracket. Engine had A.C. pump. Removed A.C.
Started engine and fan blew power steering fluid all over engine. Power steering fluid was coming from cap as though there was too much pressure.
Ideas?
rickbmac is offline
Old September 9th, 2014, 09:10 AM
Octania's Avatar
moving the alt is immaterial.
Over filled PS reservoir or a leak comes to mind as the problem
Octania is offline
Old September 9th, 2014, 09:41 AM
CutlassDad's Avatar
Any new P/S hoses that may have been built with the wrong fittings for the steering box?
There is a recent thread on this forum that addresses a similar issue.
CutlassDad is offline
Old September 10th, 2014, 06:06 PM
HUH???
There are no Oldsmobile applications with the PS pump on the passenger side of the engine. ALL 1964-1990 Olds V8s mount the pump on the driver's side. Are you really talking about the POWER STEERING PUMP or the ALTERNATOR?
joe_padavano is online now
Old September 10th, 2014, 06:43 PM
steverw's Avatar
Just out of curiosity...... Why? And what hoses did you use, and how did you route them?
Pictures?
steverw is offline
Old September 11th, 2014, 03:13 PM
HUH???
Yes, so doing this is not RESTORING the vehicle, it's MODIFYING it.
Fun71 is offline
Old September 11th, 2014, 04:36 PM
Actually, my point was that doing it isn't possible. I've never seen a bracket that mounts the PS pump on the passenger side of the engine - there is no logical reason to do it.
The fact that the O.P. hasn't been back to this thread since the first post tells me that he meant to write "alternator"...
Old September 12th, 2014, 08:50 AM
Agreed about the PS bracket. The alternator being relocated makes sense with the statement about removing the AC, although I can't imagine why anyone would do that. Maybe it's because I live where summer temps are in the 110+ range...
Fun71 is offline
Old September 8th, 2017, 06:29 AM
rickbmac's Avatar
Yes, I apologize.
Power steering pump always on drivers side.
Changed brackets only. I meant that since removal of A/C pump everything is on the drivers side of the engine.
rickbmac is offline
Old September 8th, 2017, 08:00 AM
So what caused your PS fluid to blow everywhere?
oldcutlass is online now
Old September 18th, 2017, 04:02 AM
rickbmac's Avatar
I believe air in the lines, has not repeated.
rickbmac is offline
nicks1966
January 12th, 2014 01:46 PM
russell-t
May 1st, 2011 08:57 AM
Uly49
October 20th, 2009 07:11 PM
KZ442
April 10th, 2009 03:16 AM
1FSTLS1
May 30th, 2008 07:42 AM
Quick Reply: Power Steering
