Power to Manual Steering Conversion
What is involved in converting from power to manual steering on a 1972 Olds Cutlass?
Do a I need a different Pitman arm?
Do I need a different Rag Joint?
Also, does anyone have a manual gear box that they want to get rid of???
If you get a manual steering box,make sure you get the pitman arm with it,and make sure it is for an A-body.The pitman arms appear to be the same between power & manual,but the difference is the splined hole that attaches to the box.The manual box has a smaller hole.The rag joint is a 50/50 chance that it will work on both.Some of the steering boxes have the steering shaft that is splined all the way around,and some have a flat spot machined-out.If you have a joint that is made for the flat section,then it will not fit one that is splined all the way around.
If you decide to do this,and can't find what you need,let me know.I have an assortment of manual boxes.Every Olds I own has manual steering.It is only harder to steer when the car is stopped.Once you are rolling,it is the same.
I upgraded to a u joint it made the steering a little more responsive specially with manual steering. I know flaming river sell the u joints I got mine from a friends totalled mud truck with manual steering.
I know its a burgeson joint and I belive you can pretty much get one for any app. You count the splines diameter and the shaft diameter . I asked my buddy he said he bought the shaft and u joint kit from summit for a k5 blazer. I'm gonna assume that gm used a standard size on the spline size for their gear boxes . I went from power to manual with out swithching the rag joint and I used the gear box from a 66 gto . I would post a pic but I'm on vacation as we speak ill snag a pic next week if you still want to see what it looks like
Cincinnati Rick
May 22, 2015 01:17 PM
1970442w30post
Brakes/Hydraulic Systems
Jan 20, 2011 05:06 PM
