power antena
Old Feb 25, 2021 | 12:23 PM
l6conv's Avatar
power antena
I have a 67 442 conv. with rear power antena that will not go up or down.. The motor works but nothing moves .Can these be repaired? Are parts available?
Old Feb 25, 2021 | 02:39 PM
therobski's Avatar
I will be interested in the responses-suggestions to your thread. Same issue on my 63 Starfire, though I had it fixed but??
Old Feb 25, 2021 | 03:14 PM
Tri-Carb's Avatar
K
P.O. Box 553
241 Hanging Rock
Banner Elk, North Carolina 28604
Box 553
Klaus WojakCarolina 28604
828-898-9338
He i
jak
P.O. Box Klaus Wojak
P.O. Box 553
241 Hanging Rock
Klaus Wojak
P.O. Box 553
241 Hanging Rock
241 Hanging Rock
Banner Elk
Old Feb 25, 2021 | 03:25 PM
Yellowstatue's Avatar
If the motor works then it is probably the nylon cord has become separated from the mast which usually requires a new mast. As the motor rotates, it winds up or feeds out the cord to extend or retract the mast. There is a small wire soldered to the mast and the cable screw in port. Carefully remove the port from the mast and then unsolder the wire from the mast. The tube must be removed from the motor housing. When reassembling this mess back together, feed the nylon cord into the drum (preferably with power, or not) until most of the slack has been taken up. Carefully solder the wire onto the mast and place the port back onto the tube, then fasten the tube to the motor housing and test before installing into the vehicle. That is sort of how it goes. P.S. Criticism expected.
Old Feb 25, 2021 | 04:16 PM
l6conv's Avatar
power antena
I've never tore into one of these and I know they're not cheap so I think I'll give Klaus a call first. Thanks I may be back for your help. Tony
Old Feb 25, 2021 | 04:34 PM
danktx's Avatar
How original do you need to be? You can use a modern power antenna with the dash switch with the addition of a diode.
Old Feb 26, 2021 | 05:00 AM
I used this antenna to replace the faulty one in my 96 98. It's been working great for over a year.
Amazon Amazon
It wouldn't be 100% correct for your 67 442, but nobody would find out unless the guy with the red beard told them.
Xlhowie
Jul 6, 2015 11:58 AM
64Rocket
Jun 19, 2012 11:55 PM
squirell
Apr 13, 2011 05:22 PM
Beob
Feb 5, 2010 10:09 AM
pearldawg23
Feb 14, 2008 05:08 AM
