Oil Filter Housing Gasket
Old Oct 1, 2016 | 11:47 AM
ostie13's Avatar
Im changing the oil filter housing gasket on my 455. I found a leak going down the oil filter so I took the housing off and am getting ready to change the gasket out. When I had the engine rebuilt the original gasket was metal but since I could not find a new metal one we replaced it with a fel-pro one. Since them I have found several of the metal ones,so I decided while I change my oil this time I would remove the housing and replace it with the correct gasket. My question is should I use any kind if sealer on one or both sides of the metal gasket or just use it dry.
Old Oct 2, 2016 | 06:59 AM
ostie13's Avatar
Well I hope I side it correctly. We will see. I put the slightest film of Copper RTV on the housing side of the gasket and Left the other side alone.I torqued dont on it and filled it up with oil. I will start it today and see what happens.
Old Oct 2, 2016 | 08:49 AM
The metal core gasket did not use sealer from the factory. You should be OK, but it wasn't necessary.
davidstereo
May 14, 2012 08:09 PM
ctrain22
Jul 31, 2009 05:50 AM
67_cutlass_s
Sep 8, 2007 02:49 PM
67_cutlass_s
Sep 7, 2007 09:04 PM
