Odd part search: reinforced 90deg hose bend
Old Nov 15, 2016 | 07:13 AM
oddball's Avatar
Curious if anyone has seen a part like this. The fluid cooler I'm using has an outlet pointed downward and ends up only 3" or so from the bottom of the core support. I have a 3/8" hose connected to it, but the bend is a little tight and the hose wants to collapse.
I'm looking for the same thing as a 90deg PCV elbow commonly seen on the parts store wall, but needs to be reinforced and formulated to work as a tranny cooler fitting.
Unfortunately there's not enough tube to cut off the bubble and add an AN adapter. The tube is too thick to flare for an AN nut and there's not enough room to get a good flare tool on there.
Thanks!
Old Nov 15, 2016 | 07:21 AM
Google is your friend...
http://hpsperformanceproducts.com/hp...ose-black.html
Old Nov 15, 2016 | 07:33 AM
oddball's Avatar
"Silicone hose is NOT compatible with fuel or oil."
I assume Dex/Merc still counts as an oil.
Old Nov 15, 2016 | 10:14 AM
svnt442's Avatar
What trans cooler are you using?
Old Nov 15, 2016 | 10:38 AM
oddball's Avatar
It's a three circuit unit from a Lincoln LS, nearly the size of an A/C condenser.
Old Nov 15, 2016 | 01:56 PM
svnt442's Avatar
That seems a bit on the extreme side.
Old Nov 15, 2016 | 01:57 PM
svnt442's Avatar
Like this one?
Old Nov 15, 2016 | 02:31 PM
RetroRanger's Avatar
72 Olds CS
My 2000 new holland tc29 d uses a hose like joes picture coming out of the trans cooler don't know if that would work for you.
Old Nov 16, 2016 | 06:53 AM
oddball's Avatar
Mine is the earlier unit with three circuits. That's the later year with two circuits. They had a different usage (hydraulic driven radiator fan) in the first generation. So I have one cooler for engine, tranny and power steering. With separate circuits. It's not one huge cooler just for transmission.
Retro, the problem is silicone will break down in presence of petroleum products. An OEM application probably has a liner or different formulation.
My favorite parts guy found a Gates unicoil covered in dust. Giving that a try. It's the one for 3/8" hose, but is actually a bit large for this hose. I also got the Gates 3/8" elbow, but it is surprisingly small and flimsy.
Old Nov 16, 2016 | 07:02 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Great find Sir Padavano. Looks like they may have the 90* bypass hose in this reinforced material for our Olds engines. Whats offered today is nothing like the OEM spec hoses. The new repro stuff is thin wall and bulges with RPM, new out of the box. I was forced to put a good 30 year old bypass hose on a newly detailed engine for fear of the new one bursting. The Repro hose clamps lack significant resolution to apply correct clamping force. The repro clamps work great on the OEM hose. But do not provide enough clamping force on the new junk....similar to your Deltas front shocks in which new parts that dont fit!
Old Nov 16, 2016 | 09:30 AM
oddball's Avatar
That was a good hint. Looks like that hose is a 5/8" though. Would've been the perfect part at 3/8".
Old Nov 16, 2016 | 09:52 AM
Is there enough room to use a metal elbow and a short section of straight hose? Not the prettiest solution, but it meets your needs if there's room.
Old Nov 16, 2016 | 01:26 PM
m371961's Avatar
And you can get brass barb to barb 90 degree ells at McMaster Carr.
Old Nov 16, 2016 | 04:04 PM
Yellowstatue's Avatar
There is also a wire coil that you slip over the hose. It's several inches long and comes in different sizes for the different hoses.
Octania
Jul 16, 2015 05:21 PM
Octania
Sep 17, 2014 05:11 PM
WMACHINES
Aug 3, 2014 12:24 PM
gerk
Jan 11, 2014 02:40 PM
jensenracing77
Jul 29, 2012 07:53 AM
