now i'm screwed. broken bolts
Old Oct 31, 2020 | 02:56 AM
Ray Dzi's Avatar
I need some advice on the best way to remove broken bolts that attach water pump to front cover of my 64 olds 88....394 please.
I purchased car in summer with a bad water pump and i think i know why it was not replaced. the 3/8" bolts that hold pump to block even gave me trouble but did not snap .
any help with tricks or suggestions would be appreciated. I do have a little stud left to grab on some
Old Oct 31, 2020 | 04:19 AM
Oldsmaniac's Avatar
Well that water pump housing is a separate piece so it can be replaced. It can be removed to work on getting those broken bolts out. If there is something to grab use heat and try your best but most likely you will need to drill the broken bolts out and retap new threads.
Old Oct 31, 2020 | 05:32 AM
scrappie's Avatar
If there is enough stud left to maybe get a 3/8 nut on a bit then weld the inside of nut to stud and remove?
Old Oct 31, 2020 | 06:20 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Why don't you post a picture of the stud you have left. A couple of options might be welding a bolt onto the remaining stud or using a stud extractor if there is enough stud to grab. If you haven't already you should start soaking it with PB Blaster. The stuff works wonders.
Old Oct 31, 2020 | 07:38 AM
Sugar Bear's Avatar
X2 on PB Blaster or KROIL. Warm the bolt, tap on it with a hammer, soak it, let it cool and repeat a few times. WD-40 would not be my choice for this.
Good luck!!!
Old Oct 31, 2020 | 08:06 AM
Ray Dzi's Avatar
Good luck!!!
thanks everyone.
I did soak with BP for 2 days. when i finally got pump off after snapping 4 bolts i switched to Kroil...that stuff is my go to penetrant.
Also tried heat a hammer and more soaking for a few hours and still broke off even. i guess drill and extractor my next attempt
Old Oct 31, 2020 | 08:15 AM
Ray Dzi's Avatar
That front cover is the timing chain cover i believe. I read horror stories about trying to get that front rubber seal in with oil pan still on
Old Oct 31, 2020 | 06:27 PM
oldolds88's Avatar
you can still weld a nut onto the old stud,even if it broke off flush,use slightly larger nut and mig welder,the heat from welding the nut will get it loose.
Old Nov 1, 2020 | 02:55 AM
Ray Dzi's Avatar
That's a great excuse to get a Mig welder. I was already contemplating one and you just reinforced my need to own one
Old Nov 2, 2020 | 05:09 PM
oldolds88's Avatar
every body needs a mig,handy for everything. get a non flux core. i never saw one till i hire into gm,they stuck one in my hand and told me to go at it, by the end of day 2,i was welding sheet metal door skin to window frames
Old Nov 2, 2020 | 05:37 PM
Guy Fillinger's Avatar
When I was still working I rebuilt Turbines and generators in Power Plants. I can't tell you how many hours I spent working at getting out Bolts that were like welded in from many years of extreme heat. If you drill your broken bolts or weld a nut on and you try to loosen them up. Never continue only in one direction go back and forth, even at the start if it does not move try turning the other way a tiny bit then back the other way. You need to break the scale loose and when it does start to come out turn it back like you are taping a hole. It can be a long process but it works. Good luck
Old Nov 2, 2020 | 09:28 PM
OLDSter Ralph's Avatar
X 2 It does work !!!!
Old Nov 3, 2020 | 01:30 AM
Ray Dzi's Avatar
Using that technigue I was able to remove 1 successfully then broke next 1 flush and came here for help.I learned those tricks year ago.
thanks for all the tips but 56 year old bolts around water ports and exhaust are not easy to deal with...especially since I haven't wrenched on old cars in quite some time
servexcell
Mar 26, 2021 09:57 AM
Rodolfo Elias
Jan 18, 2019 09:53 AM
Al Sanchez
Sep 6, 2013 03:30 PM
H8D-67
Aug 29, 2013 11:38 AM
1971viking
Jul 11, 2012 11:32 AM
