water pump bolt timing cover issue
Old Jul 10, 2012 | 07:04 AM
1971viking's Avatar
This problem has been discussed before but I thought I would add to the discussion. The bottom two bolts of the water pump will thread and snug up but if I try to put 10ft pounds of torque they keep turning. They water pump did not leak before and I did not strip the bolts since I was using a torque wrench. What gives? I think I will take a chance to see if it holds. They seem snug and all the other bolts are fiine.
Thoughts?
Old Jul 10, 2012 | 07:38 AM
citcapp's Avatar
I recommend that you take the cover off and weld nuts to the back side of the cover to fix the problem. Why take a chance on a leak Just my two cents
Old Jul 10, 2012 | 08:45 AM
1971viking's Avatar
You are right. I just ordered a new cover from the parts place.
The manual says 13 ft pounds for the water pump bolts. I don't want to strip out the new cover. Suggestions on torque for the bolts?
Old Jul 10, 2012 | 08:52 AM
citcapp's Avatar
The 13 ft lbs should be fine. If you don't have a torque wrench that goes down that small. Then use a ratchet and hold it at the **** not on the handle and tighten using wrist action only that way you won't over tighten
the bolts. easy does it
Old Jul 10, 2012 | 08:56 AM
1971viking's Avatar
Thanks.
Have you used the copper spray gasket for the water pump. I have a couple of friends that do but I am skeptical.
Old Jul 10, 2012 | 08:59 AM
citcapp's Avatar
Nope, just use the standard gasket sealer with a new gasket. Never had a problem
Old Jul 11, 2012 | 11:32 AM
1971viking's Avatar
Angry
I read on this forum that you don't have to remove the entire oil pan to put the timing cover off/on. They say just losen the front bolts. This would be great since the oil pan gasket is only 1 month old (composite rubber cork). Hate to take the entire pan off and start over but if that is the correct way to do it then I guess I will. Nothing like doing everything twice.
.Rocket.Man.
Jun 4, 2015 02:06 PM
rkk69olds
Apr 7, 2012 04:14 PM
Joffroi
Sep 3, 2010 07:18 AM
69OldZman
Jul 1, 2010 07:21 AM
442scotty
May 13, 2009 05:42 PM
