No build sheet
Old Nov 20, 2009 | 09:02 AM
ozbie's Avatar
No build sheet
I just picked up a '72 Cutlass 350, is there any way of confirming the original options on this vehicle...it comes with front disc brakes, center console, remote mirror, 442 tags, boxed rearend, sway bars, 8 track, wood grain dash etc...just don't know if their original or not.
Old Nov 20, 2009 | 09:18 AM
Without the build sheet, that data is not available unless the car was originally built or sold in Canada. GM of Canada has those records, but the ones for US cars are long gone.
Old Nov 21, 2009 | 05:41 AM
Blk71SX's Avatar
sadly, without the build sheet or original invoice the options can't be determined. I assume you've looked on top of the fuel tank and in the springs of the rear seat cushion.
Old Nov 21, 2009 | 11:25 AM
jaunty75's Avatar
I wouldn't assume this. Pulling out the rear seat to look in the springs is one thing. Dropping the gas tank to look on top of it is quite another! I'm not sure I would do it if the only reason for doing so was to see if, by chance, the build sheet was there.
Old Nov 21, 2009 | 02:08 PM
ozbie's Avatar
I'm pulling the car apart anyway, the gas tank seats etc...are all out...no build sheet. I was told build sheets were'nt particularly regulated back in "72, attaching the build sheet to the car was pretty much at the whim of the assembler.
Old Nov 21, 2009 | 06:05 PM
Blk71SX's Avatar
depends on how badly you want or need the info.
Old Nov 22, 2009 | 05:30 AM
Texas442's Avatar
1971 442 conv
Look behind the bucket seat backs. Also, look inside each door.
Old Nov 22, 2009 | 01:24 PM
jaunty75's Avatar
I don't think there was ever ANY regulation of build sheet placement or policy that it be placed in the car at all, pre-1972 or otherwise. As you say, it just depended on whether or not the last person on the line to see the car did something with it or not. These things were used on the assembly line and were never meant to come into the hands of the final purchaser. The fact that those of us who have found them have found them at all is just luck (or perhaps we should thank the laziness on the part of that line worker!).
Lamison
Sep 16, 2023 04:06 PM
1968 42
Feb 2, 2023 02:25 PM
rrielley
Jan 29, 2008 03:13 PM
mainedogg72
Jul 7, 2006 12:17 AM
rodknocker
Apr 17, 2006 08:25 PM
